Old 07-06-2011, 06:52 AM   #1
54mainlinetim
54mainlinetim's Avatar
Default y-block finned valley pan oil tube???
im intrested in running a finned aluminum valley pan ,i see some for sale on ebay and socal speed shop has one ,but i noticed that they dont have the oil fill tube! where is the oil supposed to go if you use this??? i figure the only other way isto run valve covers with oil and breather holes in them??but what if you wanted to run the finned valve covers that dont have holes also ??? is there something im missing??
heres a link at what im looking at:
http://shop.ebay.com/i.html?_from=R4...All-Categories
54mainlinetim is offline   Reply With Quote
Old 07-06-2011, 07:02 AM   #2
Ole Don
Ole Don's Avatar
Default Re: y-block finned valley pan oil tube???
Those parts make me think you found a bunch of Chevy parts makers failing the attemt to make Ford parts. Try Ford Y, the Mummert site. He has the parts that will work.
Ole Don is offline   Reply With Quote
Old 07-06-2011, 07:10 AM   #3
54mainlinetim
from what ive seen on his site he only has a plain aluminum valley pan not finned..which i dont mind i was just confused on these finned ones with no oil tubes!
Old 07-06-2011, 09:12 AM   #4
46yblock
46yblock's Avatar
Mummert's valley pans can come with the oil fill tube if so ordered, and if desired the rear vent for PCV.
Quite a few years ago I ordered a finned cover like being discussed. A machine shop installed the fill tube, but they mislocated the hole and angle slightly, so the thermostat housing had to be ground for clearance on one mounting ear. A bigger problem was that the cast aluminum piece had a warp that wouldnt straigten fully with the pan installed. A gob of rtv didnt prevent leaks. It was such a PITA that I threw it away.
Mike, S. Oregon 46 Ford 1/2 ton, '62 Merc Meteor S33, '54 Ford 600 tractor, '64 Falcon Futura, 1960 Thunderbird
46yblock is offline   Reply With Quote
Old 07-06-2011, 02:19 PM   #5
54mainlinetim
thanks for the replys ,i found a guy on the yblocksforever forum that welds aluminum oil tubes into them pretty slick looking....
Old 08-17-2011, 12:42 AM   #6
Trey-Deuce
Trey-Deuce's Avatar
Try this for a finned valley cover with filler tube:
http://www.rexhp.com/products.html
Trey-Deuce is offline   Reply With Quote
Old 08-17-2011, 01:14 AM   #7
Fairlane500
Fairlane500's Avatar
http://www.ace-customs.com/products.html
I have an ACE customs one very nice. Check out also Jimmys Mercury alloy rocker covers another nice piece.
Life is not a dress rehearsal...
Fairlane500 is offline   Reply With Quote
Old 08-17-2011, 08:38 PM   #8
Ray With
Ray With's Avatar
Checked out the ace soite and looks like some nice castings
Hotrodchat's Picture Gallery
26,000 pictures to keep you looking
Ray With is offline   Reply With Quote
Old 10-13-2011, 07:35 PM   #9
sling392shot
What's wrong with nice painted/ detailed stock valley pan...sure as hell won't warp and if it does a tap or two with a hammer and dolly should solve fitment issues.
sling392shot is offline   Reply With Quote
Old 10-13-2011, 10:46 PM   #10
rick55
rick55's Avatar
I have a chrome valley cover fitted to one of my engines. Looks good but is a pain to keep clean. I would think a finned cover would be even worse.
Regards
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
Old 10-14-2011, 10:10 AM   #11
Ole Don
Ole Don's Avatar
Most of the steel ones are warped. I drill and tap the block on the four corners for 12-24 screws. The two stock bolts plus the four extras keep it cleaner. A perfectly clean Y block looks unused to me. Mine is dirty, and DRIVEN!
Old 10-14-2011, 08:15 PM   #12
rick55
rick55's Avatar
Thumbs up Re: y-block finned valley pan oil tube???
My sentiments entirely Don. How many shows do you go to with absolutely pristine engine bays and when you get talking to the owner they're too scared to drive it cause it might get dirty. I am sure we have all been conned by the immaculate show engine that doesn't even have a crank or pistons inside it.
Regards
Rick
West Australia
Henry Ford
Old 10-16-2011, 04:33 AM   #13
sling392shot
Old 10-20-2011, 07:35 AM   #14
54mainlinetim
Theres nothing wrong with a stock one, I'm just a sucker for finned stuff valve covers, coil cover's,ect....I want to run finned valve covers,and finned valley pan and while i was searching came across the no oil tube valley pan, and was confused..I thought to my self if your running a finned valley pan most likely you will want to run finned valve covers and doubt you would want to cut a oil fill into the valve covers(even tho ive seen it done on some sbc ones) and was wondering how they expect you to add oil!!! To new guys to y-blocks might be disappointed if they bought one not knowing.....
