Old 01-02-2024, 09:35 PM   #1
Ron Blissit
Default special leaf spring lube
Not long ago there was a post and some one mentioned a special grease that could be used when assembling the spring. I can't seam to find it now. Any help with this would be greatly appreciated.
Ron Blissit is offline   Reply With Quote
Old 01-02-2024, 09:53 PM   #2
Gary WA
Gary WA's Avatar
Default Re: special leaf spring lube
Here's what I have used! Just like oil there will be many choices!Slip Paint
www.whidbeymodelaclub.com
Old 01-03-2024, 07:03 AM   #3
brokenspoke
Slip plate paint.
brokenspoke is offline   Reply With Quote
Old 01-03-2024, 09:07 AM   #4
BillCNC
BillCNC's Avatar
Originally Posted by brokenspoke View Post
Slip plate paint.
+1
Regards
Bill
BillCNC is offline   Reply With Quote
Old 01-03-2024, 11:40 AM   #5
old31
I have used this many times and it works great.
https://www.amazon.com/Graphite-Dry-...ps%2C87&sr=8-2
old31 is offline   Reply With Quote
Old 01-03-2024, 12:02 PM   #6
GPierce
GPierce's Avatar
Slip Plate +2
GPierce is online now   Reply With Quote
Old 01-03-2024, 03:42 PM   #7
Synchro909
Synchro909's Avatar
Before I assemble the spring, I paint it with primer that I have loaded with powdered graphite. Once assembled, I then give it a coat of black. The graphite is a great lubricant and the paint holds it in place.
Old 01-04-2024, 10:59 PM   #8
Pete
Pete's Avatar
Springs should never be assembled with grease. It attracts dirt and dirt makes good grinding compound.
Slip plate is good.(graphite base)
Dry film Moly is twice as good. (Molybdenum disulfide base)
Old 01-04-2024, 11:48 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
I used Slip plate also with spring covers (some call them gators) to keep dirt and water off springs.
Old 01-05-2024, 03:10 AM   #10
dave in australia
Agree, that's why I use molybond 122L dry film lubricant.
dave in australia is offline   Reply With Quote
Old 01-05-2024, 04:15 PM   #11
Tom Endy
Tom Endy's Avatar
I use slip plate.
https://www.santaanitaas.org/wp-cont...ration-PDF.pdf
Tom Endy
Old 01-05-2024, 07:40 PM   #12
Ron Blissit
Thank all of you who took the time to reply. I got some good usable information.This forum is really an asset.
Old 01-05-2024, 09:08 PM   #13
katy
katy's Avatar
Originally Posted by Tom Endy View Post
I use slip plate. Tom Endy
Ditto
