Old 11-12-2015, 03:31 PM   #1
36couper
Default 1940 Pickup tail lights
I will be putting my pickup back together soon. Since I'm using a new frame and new box, I need to figure out where to mount the tail lights. Does anyone have a picture they could send?
Also need to figure out what to do about front turn signals. At this point, I don't plan on running a front bumper.
Thanks
36couper is offline   Reply With Quote
Old 11-12-2015, 05:11 PM   #2
adileo
adileo's Avatar
Default Re: 1940 Pickup tail lights
Can't help with tail lights but why not use the parking lights for front turn signal?
adileo is offline   Reply With Quote
Old 11-12-2015, 05:51 PM   #3
41PICUP
41PICUP's Avatar
For your turn signals in front, use the parking lights. Bob Drake makes a conversion kit, C7G has the frog eyes glass for the headlight rim.
For taillight, my bracket bolts to the backside of bolts for tailgate hinge.
Drake and Sacramento Vintage Ford have the brackets.
41PICUP is offline   Reply With Quote
Old 11-12-2015, 06:56 PM   #4
36couper
Thanks. A great help.
Nice truck too.
Old 11-12-2015, 07:11 PM   #5
39portlander
39portlander's Avatar
Get on the early V8 web site and order "Two great trucks" by Howard Towne. Pg 26 has a good detail of what you may be looking for.
39portlander is offline   Reply With Quote
Old 11-12-2015, 07:15 PM   #6
billwill
Dont foolish Please use a front bumper how do I knowDont be sorry.better Luck
billwill is offline   Reply With Quote
Old 11-12-2015, 08:56 PM   #7
Floyd
For tail lights you need to know if you will be running a rear bumper. If no bumper then the tail light mounting is easy and pretty obvious. If you use a rear bumper, tail light mounting is way different. You should get the Howard Towne book. You are lucky in that it has just been reprinted and readily available for cheap.
Just my opinion
Floyd is offline   Reply With Quote
Old 11-13-2015, 07:19 AM   #8
36couper
I'll be buying that Howard Towne book today!
Thanks again.
Old 11-13-2015, 08:39 AM   #9
41ford1
41ford1's Avatar
This is the rear of mine. the stock tail light brackets are flipped side to side to raise the plate above the bumper.
The directional switch I used utilizes the parking lights for front directionals. The circuit for those was the same as used for the rear brake lights. I never found an ID on this 9 wire switch.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 11-13-2015, 08:54 AM   #10
36couper
Thanks 41Ford1. Very nice truck.
I just ordered the Howard Towne book. $10 plus $22.50 to ship. Crazy shipping prices for a small book to Canada.
Old 11-13-2015, 08:57 AM   #11
JSeery
JSeery's Avatar
I just looked it up and the shipping was $3.99, what is the deal with shipping to Canada?
Old 11-13-2015, 09:11 AM   #12
36couper
Not sure. Ridiculous price for shipping.
Old 11-14-2015, 06:14 PM   #13
Roger/Sacramento
Roger/Sacramento's Avatar
I went with later model taillights and bumper.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 11-16-2015, 09:19 AM   #14
36couper
I installed the tail lights with the bolts that hold the lower hinge on the tailgate. It worked like a charm.
In the picture you can see a brand new reproduction tailgate. Of course it needed a little massaging to fit.
Old 11-16-2015, 09:37 AM   #15
41PICUP
41PICUP's Avatar
Couper, if your going to have a bumper, you can flip the the brackets over and lift the tail lights up a little higher. Also makes the license plate more visible. Looking good.
Old 11-16-2015, 09:45 AM   #16
TJ
TJ's Avatar
In addition you can use the later brackets (53-56) which also move the tailamps out a bit from the bed and allow more room for the license plate.
Old 11-16-2015, 11:47 AM   #17
36couper
Thanks for the advice. I have a rear bumper but now I need to get the brackets that hold it to the frame. These trucks never look finished without the bumper.
Old 11-16-2015, 12:12 PM   #18
36couper
I thought you might be interested in a picture of the truck. this is just before I gave it a full coat of high built primer. Since this, I have taken the cab off the frame again. I was painting the primer in my pop-up portable garage. In a recent wind storm, the wind pulled it from the anchors and flipped it over breaking the windshield in my daughters car.
