04-20-2014, 10:08 PM | #1 |
Rear door check rubber on "31 Slant window problem
On the car I have the rubber door check strap wants to double up on the hinge side about 80% of the time it closes. If I exert slight pressure on it using my finger tip as it closes it does run down into the tunnel as it should. I spayed a little WD -40 on it and it didn't really cure the problem. Anyone have a suggestion as to what I can do. The other door closes as it should. An explanation of how to replace or adjust would be appreciated. Got it out of storage today and had a great day driving.
04-21-2014, 04:50 PM | #2 |
Re: Rear door check rubber on "31 Slant window problem
It sounds like the check strap is too flexible must be a repro. I still have one original and it was molded out of material like a truck mud flap with cotton fibers impregnated. My repro strap broke after a few years. Repro straps are junk.
pete |
04-21-2014, 11:44 PM | #3 |
