Old 03-23-2019, 02:36 PM   #1
Charles Reese
Charles Reese's Avatar
Default Alemite Grease Fitting
would appreciate suggestions on how best to remove the original cone-shaped (press in) alemite fittings from shackles without destroying them.
Charles Reese is offline   Reply With Quote
Old 03-24-2019, 01:08 AM   #2
1930murray
Default Re: Alemite Grease Fitting
Heat the shackle in a vice. Once cherry red, twist while pulling on the grease fitting with a pliers or vice grip. I did nine sets this way recently.
Careful as you will be burning any grease on the shackles.
1930murray is offline   Reply With Quote
