06-23-2014, 08:05 PM | #21 |
Re: How to remove front top shackle bushing?
Here is the complete KR Wilson tool set for this job. It may give you some ideas as to what you can make and how heavy duty the tools need to be.
06-23-2014, 08:08 PM | #22 | |
PS, I am one of those guys who've spent all their working lives on early Fords.....good luck,Col,. |
06-23-2014, 09:47 PM | #23 |
Henry I hope the bones are hollowed out too much. It is fixable if it is.
Hey if the spring is something you want to update from your prior build I would suggest a eaton Detroit spring. Little spendy but a life time plus replacement. Spring for your money. Keep on keeping on! |
06-23-2014, 10:23 PM | #24 |
I replaced mine on my '41 with moly impregnated nylon. Have been in for 19+ yrs and no sign of wear. If you have access to a lathe you can buy the material in rod form from McMaster-Carr and fab them any size you need.
06-23-2014, 10:44 PM | #25 |
Any mention I made of hammering was only to remove the old bushings, not to install new ones. I will most likely let a competent garage do the whole thing once I get the parts in from C&G.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
06-23-2014, 10:48 PM | #26 | |
Thanks for the idea anyway.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 06-23-2014 at 11:15 PM. |
06-24-2014, 07:56 AM | #27 | |
06-24-2014, 09:15 AM | #28 |
Get a spring shop to check your spring. Buy the picture it doesn't look to healthy. They can make you a spring if needed. It has to come apart anyway.
06-24-2014, 10:07 AM | #29 |
I'm doing the same job on my 48 F1. I removed mine with a air hammer. It worked great.
The sign of a good craftsman is how well they cover up their mistakes. |
06-29-2014, 01:50 PM | #30 |
Ive had success in the past when fitting bearings by freezing them first and warming the hub....the micro contraction and expansion of the two components made them a drop in fit.I would think a similar result may be obtained on fitting new shackle pin bushes.
I used liquid refrigerant to freeze the parts, as I have plenty in the service van with my job, but I guess leaving them in the freezer overnight would suffice.....worth a try I guess. |
06-29-2014, 04:09 PM | #31 | |
06-29-2014, 04:50 PM | #32 |
Anti seize works for me on the 34 front shackle replacement.
06-29-2014, 11:55 PM | #33 | |
I agree with Kube. Most original front springs are shot. Fortunately NOS or good NORS ones are still around for 46-48's. As Kube said.. you are better off pressing in the studs. I prefer the originals as they are still around. They are hardened, some repros are soft. Admittedly this job is a piece of cake for me as I've done many and use a KR Wilson shackle/remover/install tool as prescribed/shown in another post. If you can find someone in your local group/area who has one that is my suggestion. If you elect to try a new spring you will be glad you did. Thanks, Larry S |
06-30-2014, 12:15 AM | #34 |
I heated my spring slightly and put the bushings outside to cool, temperature was about 30 below zero. Still a pain to put them in, even with an installation tool. Just not an easy way to do this.
06-30-2014, 03:02 AM | #35 |
The spring is the easy part.
You can get the end of the spring in the vice. Two suitable sockets and the bush will go in ok. The spring, (being a spring) will have some "give" which makes it easier. I wouldn't do it on the car, though. It's those pesky perches that cause me all the trouble. Mart. |
06-30-2014, 06:37 AM | #36 |
I made 2 pieces to press/drive the old ones out and also press or drive the new ones in.. Threeaded the end so it would bottom out on the end of the new pin shaped to match the pin and bushing. Used an Arbor press on the spring and a hammer on the vehicle part. Same type for removal with the O.D. Under the 3/4 Dia. worked for me.
06-30-2014, 05:35 PM | #37 |
Got my parts in. I'll now turn it over to the pros with the right tools and equipment and experience and knowhow to make the change.
Thanks for all of your ideas. At this point, as in many of this kind of project, if I can pay someone else to do it right I'll do it. I can tell that some of you still get quite a kick out of these major repair challenges. My real joy is in just driving the wheels off and seeing where and how far I can coax Old Henry to go.
07-02-2014, 08:12 AM | #38 |
I am so in the middle of this I wish I had Video taped the whole adventure!! Going on my 4th shackle as a result of damaging them :-) FUN FUN FUN
07-02-2014, 09:30 AM | #39 |
It's actually quite an easy job with the proper tools. See post #21. That's the same set I have. Takes about 15 minutes to R&R a pin.
07-02-2014, 09:41 AM | #40 |
Henry, that spring is shot. Take a look at the main leaf as it starts to wrap around the shackle bushing. From all appearances it appears to be fractured. It looks like the only thing holding it in place is the second safety leaf. Let us know what the shop says about the spring. It wouldn't surprise me that the piece falls off after the bushing is removed.
