Old 06-14-2010, 05:57 AM   #1
40ford
40ford's Avatar
Default 1939 Ford Wheels:
Are the wheels for 36-39 the same? Does anyone have a good set of wheels for a 39 that are for sale?Preferably in North Carolina area.
40ford is offline   Reply With Quote
Old 06-14-2010, 07:01 AM   #2
1936coupe
1936coupe's Avatar
Default Re: 1939 Ford Wheels:
yes they have the same wheel stud pattern (pcd) and i have 39 hub-caps on my 36. ford pilots have same wheel as well.
1936coupe is offline   Reply With Quote
Old 06-14-2010, 12:11 PM   #3
Charlie Stephens
This is probably a dumb question but does anyone know why some centers are rivited in and others spot welded? And yes, they all interchange.
Charlie Stephens
Old 06-14-2010, 12:56 PM   #4
OLD...BILL
OLD...BILL's Avatar
Yes there is a difference in the WHEEL WITH,,, the cars with the V-8 , 60 engine are not a wide ie " 3.1/2 inch wide "as the V-8, 85's are 4 inch wide at the tire bead area. Something to look out for when buying wheels, the bolt pattern, is the same, what we call "wide five".... OLD...BILL
p.s. I have two of the 3-1/2 wide for sale? in Kalifornia,
OLD...BILL is offline   Reply With Quote
Old 06-14-2010, 01:33 PM   #5
ken ct
Bulls eye Old Bill.i was just going to post same till i saw yours. ken ct
ken ct is offline   Reply With Quote
Old 06-15-2010, 08:59 AM   #6
oldandtired
A lot of the wheels are date coded, although some I have found have no date code that is legible. Do you need 4 or do you need 5? The swap meet that used to be in Maggie Valley is coming up in a couple of weeks in Fletcher, NC...exit 40 off of I-26 at the Agricultural Center. Setup day is July 1...the meet itself runs Friday through Sunday.
oldandtired is offline   Reply With Quote
Old 06-15-2010, 09:42 AM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
Are the '37-'39, 3-1/2" wide,, wide 5 bolt pattern wheels for 60 hp vehicles really that rare/valuable? I have seen them advertised lately at $200.00 to $300.00 per pair. I always thought the '40, 3-1/2" wide, 5 on 5-1/2" bolt pattern, for 60 hp vehicles where the ones that were most wanted and the most valuable. I also have a beautiful original set of wide 5, 3-1/2" wide. wheels that came off a '37 60hp coupe. JM
John
