Old 07-08-2015, 01:09 PM   #1
36tudordeluxe
36tudordeluxe's Avatar
Default Striping question
Want to change the color of the stripe that runs around my '36 sedan. The stripe was put on with a hand held stripe device; my question is can another stripe be laid on right over the top of it or must the old stripe be removed? If it has to be removed, how is that done without damaging the acrylic enamel underneath?
36tudordeluxe is offline   Reply With Quote
Old 07-08-2015, 01:39 PM   #2
keith oh
keith oh's Avatar
Default Re: Striping question
I don't think the old stripe can be removed without damaging the enamel underneath. Maybe you could top it with a wider stipe but would look weird. Also you could try a wider plastic stripe that comes in rolls of different widths. I used it on my bumper stripes and has stayed on for a number of years, still in good shape.
keith oh is offline   Reply With Quote
Old 07-08-2015, 01:48 PM   #3
rockfla
rockfla's Avatar
Was the stripe hand painted after the car was painted? or was it done when the car was painted?? If it was hand done after the car was painted a paint professional could probably wet sand and buff it out, then you can have the new stripe hand painted to the color you want.
Old 07-08-2015, 02:43 PM   #4
deuce lover
deuce lover's Avatar
Just Google "how to remove old pinstriping" Lots of solutions.
deuce lover is offline   Reply With Quote
Old 07-08-2015, 02:57 PM   #5
36tudordeluxe
The car was painted first and then years later the stripe was added; am concerned that anymore wet sanding would go right into the primer. Will contact the striper and see what his thoughts are. Thanks for the help.
Old 07-08-2015, 05:47 PM   #6
Torchie
For what it is worth. I have used and seen many a stripper and sign painter use Easy Off oven cleaner to take off stripes and lettering on cars. And leave the paint.
Remember that the paint on the car usually has a hardener in it and stripes and lettering don't.
Maybe try it on a wheel if they are painted and stripped.
Torchie.
Torchie is offline   Reply With Quote
Old 07-09-2015, 06:27 AM   #7
Blu Dice
Blu Dice's Avatar
X 2 on Easy Off used it many times on my cars that I striped. But some colors are more difficult than others to remove and require more care. Start out slow and be patience. Pay close attention of what's happening to the base paint.
4 doors are better than no doors!
Blu Dice is offline   Reply With Quote
Old 07-09-2015, 06:27 AM   #8
BILL WZOREK
BILL WZOREK's Avatar
X3 Easy off >> Worked great in my application .
BILL WZOREK is offline   Reply With Quote
Old 07-09-2015, 08:27 AM   #9
Terry,OH
Terry,OH's Avatar
I have had very good luck removing art work and pin striping with "Easy Off" oven cleaner. Sounds like it would damage the over-all paint but it did not. Took about 5 Min. to soften the pin striping.
Old 07-09-2015, 09:12 AM   #10
V8COOPMAN
V8COOPMAN's Avatar
Easy-Off.......yellow can! Try a test spot first in a discreet location. Only takes about five minutes or so to soften. Wipe clear with WET (water) rag. DD
Click Links Below __
T5 W/TORQUE TUBE
