04-23-2024, 11:59 AM | #101 | |
Re: 276 stroker from 35 years of parts
In closing, yes, I could just go and buy all new valve components and take all this stuff to the scrapyard as I'm planning a run next month anyhow. I coulda made a lot of dough in the woodshop and paid for the new parts twice. But do we ask the avid fisherman to tally the price of his gleaming new boat, the moorage, the fuel, insurance, bait and depreciation? Heck, this dude walks right by the fish market where salmon is a mere 20.00 lb. And besides, I love working in my new shop annex....... oops, forgot the pics, will add
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 04-23-2024 at 12:06 PM. |
04-23-2024, 12:14 PM | #102 | |
04-23-2024, 06:43 PM | #103 |
That’s a very “homey” looking spot Bud!.......no wonder you like hanging out in there.....where’s the cold beverage containment system?.........Mark
04-23-2024, 09:34 PM | #104 |
Mark, A few years back when Mt Pickett Woodworking was in full swing with 3 employees, this 14x 28 'side shop' was used as a storage area for obsolete tooling, unused lumber and junk that was in our way in our daily grind. As we wound down to just me I decided to make it into a sort of 'machine shop' ( in quotes as I am certainly NO machinest). That was my winter project 2023-2024 as I already had 4 jailbar era trucks and building another seemed , well kinda borderline weird. Even for me.. Then it got addictive and I cleaned and organized the garage 2 bay side. Then 40 years of clutter in the woodshop. Homey is pretty important to me.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
04-23-2024, 09:39 PM | #105 | |
04-24-2024, 01:30 AM | #106 |
04-24-2024, 11:14 AM | #107 | |
04-24-2024, 12:40 PM | #108 |
That is one man sized wrench! I'll see that, and raise you one man sized vice grip.
I know, its brand X, but its so big it actually works. Got it at an old friends garage sale as he was in his last stretch of life from cancer. He smiled when I told him I bought it, so its a good memory too. |
04-24-2024, 01:13 PM | #109 |
I’ve never seen a 15” pair of vise grips !!........Gary...that is definitely a blood pressure reducing area.....you’re wife must have needed the sack of flour (or sugar) you used the last time you were conducting a scientific experiment.....keep up the good work ‘Ol Boy.....Mark
04-24-2024, 02:15 PM | #110 | |
04-24-2024, 10:37 PM | #111 |
Gotta love a pair of vice grips like that! I have massaged these adjustable lifters til they hold 40-60 in/lbs. Tomorrow I will drill holes in my lifter bores with my new 12" long 3/16" bit and after that there will finally be some assembly on the horizon. Hopefully not too many more decisions to make. I found what must be an NOS aluminum 8ba cam gear. I also found quite a few oil pump drive gears and various covers. My merc crank didn't come with a gear so I gotta pull one from an 8ba crank. 3 jaw puller? I have the required half bell, oil pan with the aluminum plate (with 2 long and 2 short bolts), starter plate, and surfaced flywheel for a 10" clutch. What do I want for rod nuts? Chev type? Also need the pilot bearing for T5 swap.
04-25-2024, 12:22 AM | #112 |
I believe you can just flip the cover of the oil pump over, to get a new surface. Check it with some 320 grit on a flat surface, like your fancy grinder or table saw bed.
Next, use your new toy...er, I mean lathe, and put a center on the crank bolt to use a puller for the gear....carry on |
04-25-2024, 06:57 AM | #113 |
It is best to have an actual gear puller . . . if you use a 3-jaw you'll probably only get it onto the teeth and it is very easy to break them off. Ask me how I know such things! LOL
04-25-2024, 09:54 AM | #114 |
Thank you gentlemen. I have a couple of 3 jaw pullers. What makes a gear puller different? Maybe I can adapt something I already have. I just ordered arp rod nuts and a pilot bearing to adapt the T5. On this aluminum cam gear I see the bolt holes have a step. Does it require a shouldered fastening?
04-25-2024, 10:25 AM | #115 |
Yes they are a special shoulder bolt
04-25-2024, 11:50 AM | #116 |
Thanks, and this morning I looked at that gear and remembered the step was in the cam bolt holes, not the gear. I see multiple cover plates for oil pump gear in my stash. All are cast and not reversible. I also now see that the early blocks have the idler gear shaft in the cover and 8ba have a removeable shaft which is missing in my block. I see there are shafts in blocks here, but all my 8ba blocks are in stands so I will have to hoist one out to get access. Is this shaft pressed in? I see the big circlip to retain the gear. Is it a pain to get out? Oh, and the crank gear... I pulled two 8ba cranks from a chest high shelf, gasp, but both have the gear. This harvesting of parts is becoming an actual chore. I think I'll go back to my paying work in the cabinet shop where the livin' is easy and my paws stay clean.
04-25-2024, 12:02 PM | #117 |
The shaft on the 8BA is pressed in.
04-25-2024, 02:32 PM | #118 |
Maybe I should find someone who has that shaft instead of driving one out. I'm pretty sure I can get a new one in there. I have some monster C clamps, brass hammer etc. Anybody have a picture of what it looks like out of the block? I still might remove one if it isn't a huge deal. Are they a real bugger or a tap tap tap with a brass drift?
04-25-2024, 04:47 PM | #119 |
Slide hammer. They are threaded.
04-25-2024, 05:35 PM | #120 |
Hey, sounds like a lathe project. So Skip, you still callin' that thing a 'toy'? Great news KiWin!
