05-13-2010, 01:32 AM | #1 |
32 radiator difference
Can anyone tell me if a 32 commercial radiator is the same as a passenger car radiator?
I have a commercial one but the sidebands are plain, if memory serves me right the v8 passenger cars have a swage down the band. |
05-13-2010, 07:46 AM | #2 |
Re: 32 radiator difference
This is the one that came out of my 32 Woody. As you know, the Woody is considered commercial. Hope this helps.
She just don't have the appetite For gas somehow, And Dad, I got four carburetors Hooked up on it now. I tried to hook another To see if I'd do a little good, But ain't no place to put it 'Less I perforate the hood. Wanted, lower side sections of 32 radiator cowl. |
05-13-2010, 08:35 AM | #3 |
They are the same dimensions.
05-13-2010, 09:20 AM | #4 |
The commercial will have a shorter fill neck. I had to put a taller one on the commercial V8 radiator to use in my coupe
05-13-2010, 09:41 AM | #5 |
Filler neck is shorter? I have one that came out of a pu and when it's beside a stock car radiator you can't tell the difference. My pu rad must have started out in a car.
05-13-2010, 11:42 AM | #6 |
05-13-2010, 12:04 PM | #7 |
I have not found any different neck heights, but that and the lack of a differnt commercial radiator in the parts book (there is a different one with an extra row in the truck section, not relevant here) don't mean much...'32 parts book has lots of gaps, and radiators I have are strictly whatever I have found. My commercial has a passenger grll on it for further confusion...
And of course there were multiple suppliers and presumably aftermarket radiators, so minor stamping differences are probably meaningless. The correct one is the one that isn't leaking... Model A necks '30-31 might be the explanation of a single low radiator, as I think those would go right on a B tank. Further, due to that, I have not yet tracked down a commercial cap. I do not personally believe there are neck height differences but it remains an open question! |
05-13-2010, 01:37 PM | #8 |
Dick Spadero says the commercial cap is very elusive. Had his stolen at a show. He says for a fake cap the 30/31 A gas cap is very close.
05-13-2010, 01:59 PM | #9 |
All I know is that the thing looks like a '30-31 with a slightly longer skirt below the knurled part. My roadster, though, is happily wearing a model 46 radiator cap put there by a previous owner...
Dang. Never thought of heisting Spadaro's cap! I have done some poking around in the few booths at Hershey with large stocks of original Model A parts, hoping to find that one of their '30-31 caps was taller than the others, but so far no luck. I should start taking along a Model A cap both as a size template and as trading stock in case the B one turns up on an A. |
05-14-2010, 11:04 PM | #10 |
1932tub,
All '32 radiators are interchangeable in terms of their outer dimensions and how they are mounted, including the BB radiator with the extra row of tubes, and either the passenger radiator shell or the commercial/truck radiator shell fit all of them. There is no difference in the height of the filler necks in any original '32 radiator. Despite there having been more than 100,00 of them manufactured, original commercial/truck radiator caps are indeed difficult to find today. Dave Rehor |
05-15-2010, 12:05 AM | #11 | |
may be right... it has only been about 30 years!!!
Early V8 Garage Pasadena Roadster Club |
