Old 11-15-2011, 02:13 AM   #1
Doctor's Ford
Doctor's Ford's Avatar
Default Options to paint the bumper's groove?
Just had my 33 Tudor bumpers rechromed. Unfortunately did not know the groove should be painted with black enamel and everything is now covered with shiny chrome. Any suggestions how to paint the grooves? My body shop says forget about it because no paint will stick to chrome. Wet sanding the grooves may risk scratching and damaging the rest of the chrome. If nothing will work at least I'd like to learn to do it right next time ! Manuel
Doctor's Ford is offline   Reply With Quote
Old 11-15-2011, 02:51 AM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: Options to paint the bumper's groove?
Manuel, Hola .Ford cromed then painted. You mask out the groove then rub it with the Nilon pad (Dish/ pad , Barilio ) not sure what you call it .Degrease .Then spray with single stage solid colour .or sign writers enamel .Or you could etch prime with the clear etch before the top coat .
buena compra
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 11-15-2011, 02:59 AM   #3
ken ct
Use a paint pen. Its like a magic marker only contains paint.Very easy to follow the groove with it.Hobby shops carry it.Did my 36 bumpers yrs ago still looks good. ken ct usa
ken ct is offline   Reply With Quote
Old 11-15-2011, 03:09 AM   #4
flatheadfan
flatheadfan's Avatar
The purists don't like this but I have always used pinstripe tape. In my opinion, the only differences between pinstripe tape and actual paint is it looks better and seems to last longer.
Tom
flatheadfan is offline   Reply With Quote
Old 11-15-2011, 04:56 AM   #5
coupe5w36
coupe5w36's Avatar
I also used tape on the rear of my '36, but used red reflective tape rather than a solid color. I know that the rear lenses have a reflector effect, but at night I now have 2 red lines that go the full width of the car.
Peter.
coupe5w36 is offline   Reply With Quote
Old 11-15-2011, 05:10 AM   #6
coupe5w36
coupe5w36's Avatar
Red reflector tape on rear bar.
Old 11-15-2011, 09:42 AM   #7
36tbird
Peter, that is one great idea. I may have to steal it!
Also, I hate to tell you this, but your rumble seat step pads are on the wrong side of the car.
36tbird is offline   Reply With Quote
Old 11-15-2011, 09:45 AM   #8
Doctor's Ford
All right. Three good simple ideas that will fix my problem. Will give a try with the paint pen first or just use the pinstripe tape. Cool. Muchas gracias Barners. Manuel
Old 11-15-2011, 09:59 AM   #9
TJ
TJ's Avatar
I've used the tape also and it works fine.
Old 11-15-2011, 10:34 AM   #10
wga
wga's Avatar
Use One Shot paint enamel. My son does pinstriping and has done this numberous times. Looks great and lasts for years. Tape will fade, edges will lift.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 11-15-2011, 10:35 AM   #11
V8COOPMAN
V8COOPMAN's Avatar
If you'll note, the steering wheel is also on the "wrong" side of the car......for us Americans, that is. It's an Australian, right-hand-drive car. If you'll remember, Henry DID NOT put the outside, key-operated locks in the doors on the drivers' side back in those days, to promote safety by entering the vehicle on the passenger side, away from passing traffic. Same idea with entering the rumble seat area from the NON-street side. DD
Old 11-15-2011, 10:42 AM   #12
barnfind08
I think tbird was tongue and cheeking the response.
barnfind08 is offline   Reply With Quote
Old 11-15-2011, 11:47 AM   #13
Joe KCMO
Joe KCMO's Avatar
I painted my 39 over the chrome with no prep work except washing. Nine years later, still there.
Joe KCMO is offline   Reply With Quote
Old 11-15-2011, 12:11 PM   #14
36tbird
Thanks, barnfind. Looks like another attempt at humor on this forum has gone awry.
Old 11-15-2011, 04:58 PM   #15
coupe5w36
coupe5w36's Avatar
Don't worry 36tbird, I had a chuckle when I opened the computor this morning
