03-27-2017, 05:08 PM | #1 |
Roadster top rest problem
I have a pair of 28/29 brass roadster top rests I bought at a swap meet recently. They look pretty good, except for a shallow dent in one that hopefully can be removed by the plater. Anyway, I can't get the standoffs removed from the main part - none of them. I suspect the pot metal the standoffs are made from swelled some, even though they look OK. I am looking for a way to free the standoffs so I can get everything nickel plated. I though of using an acetylene torch on the top part to expand the metal a little, but I am concerned the heat might cause some damage. I don't want to damage any of the parts. If anyone has an idea on how to remove the standoff, please post a response.
Rusty Nelson |
03-28-2017, 08:16 AM | #2 |
Re: Roadster top rest problem
Don't put heat on it
spray with lube or maybe a little coke cola and let set for a little bit and take a pliers and try twisting them. they should come off without to much problem if you are set on heating them maybe hot water will work for you good luck Tinkirk/Terry |
03-28-2017, 08:41 AM | #3 |
Rusty, are you trying to save the stands? I doubt they will plate nicely anyway, so use a Dremel and split them where you can break them in halves.
The small dent can probably be filled with silver solder and filed smooth. Good find on those as I am looking for a set of decent brass ones also. |
03-28-2017, 09:35 AM | #4 |
Brent
if they are nice how much are they worth? |
03-28-2017, 09:49 AM | #5 | |
So,....if the Aluminum ones won't plate up nicely, machine new Aluminum stands or Brass? Uhh....is that correct?....are the originals "pot metal"? I thought they were Aluminum..they feel like Aluminum? |
