Old 09-12-2016, 10:57 AM   #1
53_mercLuke
Default Transmission oil for a 1953
I am running the stock 3 speed manual transmission with overdrive in my 1953 Mercury. I am just curious what kind and weight of transmission oil y'all would recommend?
53_mercLuke is offline   Reply With Quote
Old 09-14-2016, 09:16 AM   #2
speedshift
Default Re: Transmission oil for a 1953
I use Sta-Lube Hypouid SAE85W90 rated API/GL4 purchased over the counter from my local NAPA store. Made to specs for older manual transmission with brass synchros.
It even smells bad just like original.
speedshift is offline   Reply With Quote
Old 09-14-2016, 09:22 AM   #3
speedshift
I use Sta-Lube Hypoid SAE 85W90 rated API/GL-4 purchased from my local NAPA dealer. It is made to meet the specs for older manual transmissions with brass synchros.
Even smells bad like the original.
