04-06-2012, 10:19 AM | #1 |
1953 customline steering wheel parts
I have a 1953 NOS customline steering wheel that I want to put on my 53 f-100, my problem is I dont know what other parts I will needd .I have the horn wire and the spring for under the steering wheel, but I dont know what else I need or even what the parts look like any pictures or info where to buy these parts would be a big help.
04-06-2012, 02:28 PM | #2 |
Re: 1953 customline steering wheel parts
Try Mac's Antique Auto Parts. I have a 53 Customline and I've been able to find almost everything I need from them.
http://macsautoparts.com/1949-1959-f...id/F50/ca/146/ |
04-06-2012, 03:45 PM | #3 |
One of the suppliers should have pictures you can compare between parts but the column bowls, horn, & turn signal cancelling cams may be different. The truck & car chassis parts books for 1953 usually include the earlier vehicles back to 1948/49 so they may or may not have illustrations that will help. I've got one for the 53 car but my truck book is up to 55 so I don't know if it will have details for a 53 F100
PS: I looked at the illustrations in the chassis parts books and the bowls are a bit different. If the shafts have the same retention set up a person would have to try it on there & see if it will work. If the bowl is a different diameter it might look a bit odd or if the gap it too narrow or wide between the bowl & wheel, there might be a big gap or possible interference at that point. The car wheel should have a horn ring where the F100 would have a center cap horn push. Both have the horn wire going down the steering shaft & out the steering box end on the bottom. Last edited by rotorwrench; 04-06-2012 at 04:01 PM. |
04-13-2012, 05:03 PM | #4 |
