Old 07-24-2010, 09:31 AM   #1
JDakota
Default clutch release bearing
Turn the bearing until the lubricator fitting is at the top? I see no fitting on the bearing, I see a stationery fitting near the spring but nothing to turn. Could someone explain this.
JDakota is offline   Reply With Quote
Old 07-24-2010, 09:48 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: clutch release bearing
I believe that is for the milti disc clutch in 1928
Old 07-24-2010, 10:05 AM   #3
Tacoma Bob
Tacoma Bob's Avatar
mmmmm I don't believe the throwout bearing has a grease fitting. The sleeve has a fitting (by the spring)
Tacoma Bob is offline   Reply With Quote
Old 07-24-2010, 10:10 AM   #4
Colorado Greg
Colorado Greg's Avatar
I am putting in a new clutch today in my '29 Coupe and I have everything all apart right now. The hub is the only thing that has a grease fitting. The throwout bearing is a sealed unit without a grease fitting.
As mentioned above, maybe the multi-disk units had a grease fitting but I do not know if they did or not. Hope that helps.
Greg
"Betsy doesn't leak oil - she just marks her spot"
Colorado Greg is offline   Reply With Quote
Old 07-24-2010, 10:16 AM   #5
Glenn C.
Glenn C.'s Avatar
The hub has two holes that allows the grease to move into the center of the bearing between the two halves. You grease the hub, grease moves around and along the input bearing retainer, and escapes through the holes to the bearing.
Glenn C. is offline   Reply With Quote
Old 07-24-2010, 10:42 AM   #6
Patrick L.
Patrick L.'s Avatar
Yep, like the boys said, one grease fitting that sends grease to both the bearing and collar.. 'A little dab will do ya' ..
