Old 04-01-2013, 12:22 PM   #1
Ford coupe
Talking HELP Need my spare of my 36 cope
O K when trying to get spare tire off my 36 coupe Pushed in on lock and tried to turn right but to no avail..Also tried turning left ..Seems the tumbler turns a wee bit maybe 1/16 to 1/8..Can hear something maybe hitting down in there but??Does the little cap that is about 5 inches round come off before trying to unlock??The main cap hinges down to expose the smaller cap that surrounds the lock it self..Help guys
Ford coupe is offline   Reply With Quote
Old 04-01-2013, 04:26 PM   #2
jerry/tx
Default Re: HELP Need my spare of my 36 cope
No help here . Same problem I had . You will have to put your thinking cap on for this one. Mine was a standard coupe and it took a while . I took my mount off and cut a small hole in the back of the mount so I could access the lock from behind . Used a couple of screwdrivers to push the ears together and the lock was out . Welded the piece back in and done . Forgot that you need to buy A Nos LOCK FROM JOHN McClure and your good to go .
jerry/tx is offline   Reply With Quote
