11-20-2011, 05:15 PM | #1 |
starting problems on my 37 pick up
I have a 37 Pickup, and the battery seems to go dead after I drive it around a little bit. It will run tell I trun it off my self, but the battery is dead when I go to start it right back up again. Im a kinda new at this, so dont laugh if this is a rookie question.
11-20-2011, 05:32 PM | #2 |
Re: starting problems on my 37 pick up
is the batt hooked up + ground? do you have a working amp gage? is the generator working, is it polerised? start car pull + cable off battery, do you get a spark with every thing off? start engine, pull + cable off battery, if it keeps running the the gen is putting power into the battery, if engine dies the gen is bad
11-20-2011, 06:33 PM | #3 |
yes the battery is hooked up with + gounnd. the guage sits just above 0 at idle. when you give it gas it go's up a 1/3 of the way to 40, then drops back down to where it sits at idle. dont know about the polarize thing. what is that?
11-20-2011, 08:02 PM | #4 |
If it shows a charge when you give it the gas, it is working fine as faar as polarization is concerned. Should show discharge when you turn the switch to on position.
11-20-2011, 08:39 PM | #5 |
I would say you need a new battery.
11-21-2011, 03:02 PM | #6 |
