08-19-2013, 06:09 AM | #1 |
V8 fuel pump as an air pump? - Racecar
I was talking with an old racer over the weekend. He mentioned when he started racing flatheads he would use a hand pressure pump to initially prime his fuel system to get to the carb. Then from that point on, he had the stock fuel pump working as an air pump to pressurize the gas tank (sealed).
I was wondering if anyone had ever done this. Any thoughts? Thanks Zach
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads Last edited by SUHRsc; 08-19-2013 at 06:18 AM. |
08-19-2013, 06:22 AM | #2 |
Re: V8 fuel pump as an air pump? - Racecar
Never heard of it but sounds reasonable. Seems 5# of air ought to pump some fuel. Walt
08-19-2013, 08:03 AM | #3 |
Zack,
A while back in stash of fp's I found a ,shall we say one sided pump,....just the outlet....I wondered what it could be.....now I know. I'll bring it to Hershey. We'll stop at your place and drop it off on our way. I'll never use it . Charlie ny |
08-19-2013, 08:07 AM | #4 |
Charlie, that sounds great!
Anxious to meet you anyways! thanks! Zach
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
08-19-2013, 08:35 AM | #5 |
There's a guy over here in the UK that ran a flathead dragster back in the day. Ken Cooper. I witnessed him prime the tank and then allow it to continue to run with the mech pump pressurising the tank. We have those neat units with the mechanical primer. That's what he used. This would have been in the mid 80's but the car was built a long time before that.
Mart. |
08-19-2013, 12:02 PM | #6 |
I like those British pumps with the hand levers...wish I had one! |
08-19-2013, 03:46 PM | #7 |
It was a common thing down here in speedway .
08-19-2013, 04:56 PM | #8 |
About 25 years ago I got a 1900 steam car running for an Austrian friend. It hadn't been running for 30 or 40 years. It had a round brass gas tank about 14 inches in diameter 24 inches long with about 1-1/4" real fine threaded cap with about 1 1/4 inches of threads. Gas was put in the tank and it had an air valve for air and a hand pump. I didn't like. It was a pain to get fired up and dangerous. It had another tank the same size for water. I converted it to propane and he was happy. He took it to Austria and sold it to someone in Germany a few years later. G.M.
www.fordcollector.com |
08-19-2013, 05:31 PM | #9 |
Bruce is right as always.
It shows this very set-up in the Bill Fisher Speed Manual. |
08-20-2013, 10:12 AM | #10 |
How's my old friend Lunkenheimer doing over there?
08-20-2013, 11:17 AM | #11 |
Same kind of sources: "old racers" have told me the same thing. It makes sense since the pump isn't working under the same handicap that Ford designed; namely having to pull/lift the fuel via suction. Hand pump enough pressure into the tank to get you going and let the fuel pump maintain. After all it doesn't take too much pressure to satisfy a pair of 94s.
08-20-2013, 11:25 AM | #12 |
You'd find out quickly if your tank had any pinholes!
'52 F-1, EAB flathead |
08-20-2013, 09:07 PM | #13 |
Probably the fitted a heavier spring under the diaphragm, to up the delivery pressure.
08-26-2013, 06:36 PM | #14 |
Zach,
A friend of mine did just that on a banger powered vintage sprint car that was actually raced. The hand pump was non-functioning. PM me if you would like his name and phone number. |
08-26-2013, 08:06 PM | #15 |
When I was growing up, a neighbor's older brother ran sprint cars using the hand pump and the stock fuel pump as an air pump. It seemed to work very well. I don't recall fuel delivery ever being an issue.
Henry |
09-10-2013, 09:50 PM | #16 | |
Thank you Charlie!!! Any guesses as to the original use? Seems it'll be perfect for my racecar project!
-WANTED-
