05-19-2014, 01:40 PM | #1 |
'40 coupe bumper bracket
While preparing the front bumper brackets I noticed a difference in shape and lengths of part A and B. Part c and d are the same.
Comparing A and B measurement one is 19 inches tip-to-tip while the other one measures 20 3/4 inches tip-to-tip. Surely, 20 3/4 is correct for both; does anyone know for sure? thank you, fordman |
05-19-2014, 01:59 PM | #2 |
Re: '40 coupe bumper bracket
I'm not sure what "correct" is, but both mine measure 20 1/4". Your A bracket is just bent more out of shape than the B.
05-19-2014, 02:04 PM | #3 |
There is a difference between Standard and DeLuxe brackets for grill spacing. KUBE would have explicit details. DD
05-24-2014, 12:11 AM | #4 |
The Drake catalogue has a great picture with dimensions. Good Luck: Fred A
05-24-2014, 07:36 AM | #5 |
The "A" and "B" braces are 19 1/4" when measured tip to tip on a DeLuxe model. The Ford V8 model "A" and "B" braces were 18" if I recall correctly.
