03-25-2012, 09:07 AM | #1 |
Hub Bolts
Just removed the hub bolts "studs" from one of my rear brake steel drums. I have the swedging tool from Snyders but my press isn't big enough to swedge the new bolts. Would it be safe to weld the studs in ? I would rather put them in the correct way but finding a shop willing to do it isn't looking good.
03-25-2012, 09:41 AM | #2 |
Re: Hub Bolts
The studs should not be welded in, they should be swedged. As well, the face of the hubs should be turned on a lathe to true up the faces before the drum is installed. While welding the studs in may work, the upset part of the stud that should have been swedged down level with the face of the drum, may interfere with the correct setting of the wheel on the drum. You should get it done correctly, a local machine shop shop should be able to do it, seeing as you have the tool.
03-25-2012, 09:48 AM | #3 |
Re: Hub Bolts
Not a good idea to weld them, for 2 reasons...
First - the wheel bolts have a shoulder (that you'll swedge against) that could interfere with the wheel seating properly Second - Welding the bolt could make it brittle, allowing the wheel to escape from the vehicle without notice I was tempted to weld mine in too, but look around for either a machine shop or a friend with a larger press. Maybe you just need a higher capacity bottle jack for your press ? Just my 2 cents.... |
03-25-2012, 09:58 AM | #4 |
Re: Hub Bolts
Use a 20 ton press (minimum) or 30 + Ton prefered. Don't weld or you will have problems down the road.
03-25-2012, 11:02 AM | #5 |
Re: Hub Bolts
I had new studs swaged in by a local auto machine shop using their tool. I supplied the tool I bought from Brattons but they couldn't use it because it wasn't hardened and just "mushed" out under pressure. I removed the old studs using a 5/8 steel hole saw in my drill press and knocking them out with a 2# hammer. No warping or out of round problems.
03-25-2012, 11:33 AM | #6 |
Re: Hub Bolts
03-25-2012, 12:25 PM | #7 | |
Re: Hub Bolts
03-25-2012, 01:00 PM | #8 |
Re: Hub Bolts
What diff does it make if it's off an 82-yr-old car or a 2-yr-old car? This seems like a bogus argument. It sounds more like they just don't know how to swage. Sign a release if they're concerned about liability, but I can't imagine why they would be.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. Last edited by 700rpm; 03-27-2012 at 12:07 AM. |
03-25-2012, 01:07 PM | #9 |
Re: Hub Bolts
The tools from the vendors are not hardened like was mentioned earlier. Don't use them. I tried and it went to heck in a heartbeat. It also twisted the sh?? out of the press. Had a friend make new hardened swedge tool and have done several sets of drums with no problems.
03-25-2012, 03:12 PM | #10 |
Re: Hub Bolts
Think you're right...they prob don't know how to swedge. Sounds like my swedging tool is gong to be usless also.
03-26-2012, 06:29 PM | #11 |
Re: Hub Bolts
Well...tried another shop today. This guy tried one stud but was afraid the tool would kick out and stopped. Guess I'll try to figure out how to drive on 3 wheels !
03-26-2012, 07:33 PM | #12 |
Re: Hub Bolts
I don't know if this will work for you, but here is what I have done before, If you can rig a setup to support the hub and drum and back the hub bolt this could work. I Have used a large tip with the acetelene torch and heated the lug where it protrudes through the hub and drum. I heat the lug very hot, just before the sparks begin to fly, slip the tool over the lug and whack it quick with a three or four lb. hammer before it can cool. I clamp a pair of round jaw vise grips on the tool to hold it with. It helps if you have someone to man the torch, so that you have both hands to work with. It will take several heating and hammerings to get the lug really tight. Don't try quinching the lug, It will make it brittle. I have only done this where I only needed to replace one lug. The available lugs have longer sholders and you may have to use a tapered lug washer under the lug nut to compensate so that the nut will tighten enough. This is just something that I have done and I really will make NO recommendation. I have also used hubs and drums with all of the lugs brazed to the hub with NO problems. The problem with welding or brazing the lugs is that the weld can't stick out very far on the rear or it will cause problems by striking the emergency brake assy. Good luck.
03-26-2012, 10:49 PM | #13 |
Re: Hub Bolts
It's not a big deal and I can't imagine someone close by won't swage the studs. I had to cut a little off the stud shoulder using my lathe because I was reusing my steel drum. I used the swage tool Bratton's sells.
03-26-2012, 10:59 PM | #14 |
Re: Hub Bolts
Find a shop that does big rigs they can do that job.
03-27-2012, 12:25 AM | #15 |
Re: Hub Bolts
While swaging the bolts are the best my car had them welded in the 1980's. No problems with the welds. Once the drums wore out I had the new ones swagged in.
03-27-2012, 12:41 AM | #16 |
Re: Hub Bolts
A 25 ton press will struggle to finish the job, 20 tons won't do it properly -----if it was trying to "kick out" I would think there was a problem with the setup ---I used a 40 ton press, it was easy to feel the metal move---then it came up on 24 tons you could feel the movement stop, it was finished ---in looking at the metal movement on some of the original ones it seems that much more force was used because of the distortion of the head of the stud ---the stamped hub design needs the drum "rivited"to the hub to be strong, then adding the wheel makes it stronger.
03-27-2012, 05:04 PM | #17 | |
Re: Hub Bolts
Thanks Purdy....I can see that trick might work if i can rig up somethng to hold the back of the stud and drum. May have to try. You are right about welding...not a lot of room inside. Wonder if a guy were to cut a few grooves into the new stud and hub and then lay the weld in those ? If i needed to grind a bit off to clear the brake at least there would be enough weld left to hold....just a thought. I really don't like the idea of welding but....??? I tried what i thought was one of our biggest machine shops today but he said his press was to small. Thanks guys for all the help.
03-29-2012, 04:02 PM | #18 |
Re: Hub Bolts
Well tried another machine shop but no luck.
03-29-2012, 04:59 PM | #19 |
Re: Hub Bolts
If you have a junk 1928 multiple disc flywheel , it might work for setting up the drum to back the lugs. Just a thought.
03-29-2012, 07:50 PM | #20 |
Re: Hub Bolts
Thanks Purdy, Don't have anything like that. Did get a very hard piece of round stock today for backing and going to try the press at my work. Boy I tell ya...if you don't have the tools to do a job yourself then you're in trouble...machine shops are a joke !
