02-01-2012, 10:05 PM | #1 |
Temp Gauges
How accurate is a Motometer vs. a manual (modern) temperature gauge ?
I've just about got my truck ready for the road, and a few friends have (well meaning) have expressed concerns about the lack of gauges (oil & water) because of the amount of time and money I have invested in this project - they say forget the originality factor - protect the investement Scott |
02-01-2012, 10:10 PM | #2 |
Re: Temp Gauges
31 Pickup ...........................
The Motormeter was designed to give you a general idea, as to if your engine was heating up, only. MIKE |
02-01-2012, 10:15 PM | #3 | |
Re: Temp Gauges
they lasted 80+ years no problem. IMHO i would just use the motometer. |
02-01-2012, 10:15 PM | #4 |
Re: Temp Gauges
I have a thermostat, the motormeter reads "radiator" temperature, the 1 time I got it to the top I also had steam (my fault, running on a dyne without a fan, 2nd gear pulling a good load)
A new Mercedes has nothing to monitor oil pressure, just oil level and oil condition, no more temp gauge --but engine temp can be brought up on the display. The model A doesn't need oil pressure, just flow. If you buy a motormeter test it ---mine is a 40 year old repro and is accurate, they might not be as good now. |
02-01-2012, 10:35 PM | #5 | |
Re: Temp Gauges
Good question and one that we have all asked or thought about when we first met Henry's Lady. You will not need guages. Once you are "one" with your Model A you will develop a sixth sense that will alert you to the slightest change. You will smell and identify the faintest odor. You will feel and read what the vibrations in sole of your foot is telling you. Your ears will be tuned to the distinct chuckle of your engine. Your Model A will cease to an automobile and will become a part of who you are. Owners that do not bond with their Model A's and only use them to hold up a car cover have little use for guages they don't know how to read. Rainmaker Ron |
02-01-2012, 10:36 PM | #6 |
Re: Temp Gauges
If you're determined to be able to monitor the temp, I would not rely on the Motometer. A common cause of overheating is loss of coolant, after which the meter's sensor is hanging in the air and of little use--just when you need it the most; a modern temperature gauge sensor will be down closer to the block and more dependable. I installed a temperature gauge last year, but mostly because someone had given it to me. Also, put in a tach, which is truly unnecessary. I just like gadgets. If you want to protect your investment, I would install an oil filter and a thermostat. -- now, we brace ourselves for the horror stories of oil pump failure. Steve |
02-01-2012, 10:36 PM | #7 | |
Re: Temp Gauges
Cowtown A's |
02-01-2012, 10:58 PM | #8 |
Re: Temp Gauges
Thanks guys, I guess everyone just had me a little paranoid
Was thinking about a motometer any just to 'dress it up' anyway You guys really made me think about becoming "one" with the truck - ID'ing sounds and smells, noises, etc. - really getting me 'itchy' to drive it ! |
02-02-2012, 09:44 AM | #9 |
Re: Temp Gauges
You could do both................m/meter for looks, temp gage for accuracy.
Paul in CT |
02-02-2012, 10:30 AM | #10 |
Re: Temp Gauges
Has anyone determined a way to 'extend' the MotoMeter's probe?
Seems to me (but I'm new at this and not yet 'one' with my A) the end of the probe will most times be measuring the temp of the air at the top of the rad, rather than the water temp. The water needs to be touching the probe - that's very full... Something temp conductive to attach to the bottom of the probe, yet flexible to not damage the tops of the tubes and allow opening of the cap. Kinda like Bob Johnson did with his digital MotoMeter conversion - only for an original thermometer style, the extension would need to be a different construction (no kidding!). (31 Pickup - you might want to look into the digital conversion - perhaps a compromise that will serve your purpose... I have it downloaded if you'd like a copy...) Any ideas?
- bogie '31 (Mostly) Roadster |
02-02-2012, 10:49 AM | #11 |
Re: Temp Gauges
I installed a motometer first but because of all of my issues with cooling I added a temp gauge. I have since resolved my cooling issues but I kept the temp gauge. Here in Oklahoma with 100+ temps it's a nice bit of reassurance.
Oklahoma City Model A Restorers Group. |
02-02-2012, 02:08 PM | #12 | |
Re: Temp Gauges
02-03-2012, 02:59 PM | #13 |
Re: Temp Gauges
After an overheating problem, caused by a marginally cooling radiator, which totally ruined a newly rebuild engine, I would not rely on anything other then a water neck mounted temperature gauge. I never realized I had a serious problem until it was too late because all the water exited the radiator through the overflow tube, never saw a bit of steam from the radiator cap. I would protect your investment and add a temperature gauge, you can always remove it later after you're comfortable about how your engine will respond to different operating conditions.
AL in NY |
02-03-2012, 04:56 PM | #14 |
Re: Temp Gauges
The installation of a temp gauge is a prudent thing to do if you plan to do serious driving of a Model A. I installed a mechanical temp gauge on my Victoria a few years ago with the bulb inserted into a boss on the water return casting on the head. I also installed a 160 thermostat in the upper hose.
If anyone is interested in seeing photos and a description of the installation it is posted in the "tech article" section of www.ocmafc.com. Click on my name in the tech menu and scroll to the article "temp gauge". The temp gauge won't be of much help if you don't have a radiator capable of keeping the engine temp in line. Tom Endy |
02-03-2012, 06:43 PM | #15 |
Re: Temp Gauges
I ran a large Boyce Universal Moto-Meter on my'30 coupe, when it would slowly rise and then drop quickly in regular cycles, it was a sure fire indicator of LOW water level.
Drop a large head nail into overflow tube and you have a vibrating splash guard to prevent loss of water. There's a lot of water turbulance in that area when you're "ROARING ALONG." Bill W's Ghost (Claude's idea, not mine!) He's the REAL GURU!
02-03-2012, 07:55 PM | #16 |
Re: Temp Gauges
I installed a thermostat housing that has ports in it for the temperature bulb and hot water hook up as well.Very nice unit, even comes painted, ready to go. Installed and running with no problems at all. It comes with a thermostat.
www.VintagePrecision.com Last edited by Jim Parker Toronto; 02-03-2012 at 08:15 PM. Reason: Added source.. |
02-03-2012, 10:42 PM | #17 |
Re: Temp Gauges
SOLD !
I'm getting a temperature gauge - too much $$ invested, to find out too late. Thanks EVERYONE for your opinions - one more reason to love the 'barn' oh, and not one oil pump horror story ......... |
02-04-2012, 12:35 AM | #18 |
Re: Temp Gauges
Great! If you get the Vintage Precision water outlet Jim suggested, it is mainly designed as a thermostat housing. It is tapped for either the mechanical of electric temperature gauge, assuming you don't want to use one for a hot water heater.
Steve |
02-04-2012, 01:02 PM | #19 |
Re: Temp Gauges
Here is my temp gauge set up. Used plastic conduit and routed wire through electrical hole in firewall. Bracket and pipe from Mikes and NOS temp gauge for $12 off ebay. About $50 total. Good luck!
02-04-2012, 01:30 PM | #20 |
Re: Temp Gauges
I have used the water neck tapped sensor and the inline setup that Lyn is using. I found that the inline was 10-20 degrees cooler on the temp gauge.
