08-27-2012, 05:23 PM | #21 |
Re: 24 Hours
On the hip joint...this is a commercial vehicle, not a car, so the hip joint needs to be black-painted carbon steel. Changing it out is going to hurt but really should be done.
On the metal fatigue...everything large on an A has been cycled a probably large but utterly unknowable numer of times! Even on a car built largely from its original parts, many things are exchanged, like connecting rods, and of course a great many A's are built up from parts from MANY cars. Some of your parts might have 100,000 miles on them, others might have served several times that on multiple vehicles and parts exchanges. A single trip is going to be an infinitesimal fraction of the history of almost any major part in the vehicle...anything in there MIGHT have been run to death and ready to break in half next time you back out of the garage, but it seems pretty unlikely. And it no longer has to endure pitted, crowned hardscrabble roads carrying 3 people and 11 hogs...modern life surely looks soft to most Model A's. 24 hours would still be within a reasonable oil change cycle. Next...pilot relief tube, hole in roof for helicopter delivery of food, building a dry-break refueling connection onto tank for the refueling probe... |
08-27-2012, 05:28 PM | #22 | |
Re: 24 Hours
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
08-27-2012, 08:25 PM | #23 |
Re: 24 Hours
In the period just after WW2, my uncle used to drive a model A from east Texas to NYC non stop. (well stop for gas). I think it was harder on my uncle than the car.
08-27-2012, 09:18 PM | #24 |
Re: 24 Hours
In 1964 Ford rented a racetrack for a month and had a fleet of Mercury Comets run a durability test where they were run at speeds in excess of 100 mph, 24hrs/day to rack up 100,000miles. The cars had to carry their own spare parts in a plywood box where the back seat was. Out of 5 cars, I think 4 of them completed the challenge.
On the Model A side of things, you have to consider the engines that were used in stationary applications like compressors and light plants. Some of them would have been run for days at a time. I think you may be reading too much into things with regards to metallurgic effects. As long as the equipment is operating within normal parameters with regards to cooling and oil pressures, it likely favors being run in constant use, rather than many heating and cooling cycles where the components are expanding and retracting at different rates. |
08-28-2012, 09:50 AM | #25 |
Re: 24 Hours
A good engine is kind of steady-state; temperatures, pressures, etc. remain the same as it runs for long periods of time. Aside from loss of oil and contamination of oil, which is almost inevitable from combustion products and perhaps enhanced in an A by lack of PCV and thermostat, along with pretty open access without real filtering through filler.
