Old 09-13-2023, 01:37 PM   #1
Garwood
Garwood's Avatar
Default Recommendation for rim / tire combo
I have stock rims and tires but want to switch to radials. I also love the look of the bigger hub cap so might as well change both.
I'm thinking about getting '32 18" or the '33-'34 with the 17" but what would be the less expensive tire?
Would '35 16" work or would that be too much white wall? I think there are more choices for tires for the 16".
I'm going to Gilmore Model A meeting and swap this weeking so hoping I can get some info before I find something and buying them without knowing more.
Thanks . . .
Garwood is offline   Reply With Quote
Old 09-13-2023, 01:53 PM   #2
ronn
Default Re: Recommendation for rim / tire combo
if youre going larger, just buy the 16s.
as discussed before, 17 tires are hard to come by. 18s, why bother? might as well stay stock.
Old 09-13-2023, 01:57 PM   #3
Garwood
Garwood's Avatar
That makes sense. I've seen 16" rims cheaper as well. Plus, it sure does make them easier to spot due to the valve stem location.
Old 09-15-2023, 12:07 PM   #4
springerpete
springerpete's Avatar
You will get many, many opinions at Gilmore. You will also see hundreds of Model A's and should be able to pick a wheel size that looks good to you, tires too.
springerpete is offline   Reply With Quote
Old 09-15-2023, 07:23 PM   #5
JayJay
Several folks in my club have 16" whitewalls on their Model As, and I am going that way for the '30 town Sedan I'm building. Yes, the really wide whites are noticeable, but I don't think excessive. The 16" are considerably less expensive on the swap meet market than the 17", likely because there are more of them around.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
JayJay is offline   Reply With Quote
Old 09-15-2023, 11:42 PM   #6
30Murray
The only problem with 16" rims is finding tires that are narrow and tall enough to fit the 4" wide rims, look good and fit your budget. You can go modern radials for lower cost but very limited selection that fit, or classic bias look (Coker) for $$$$. I would suggest researching Tire Rack for modern radials and Coker or similar for classic to first see what's available and fit your budget. I ended up getting some 16" rims widened to fit modern radials with similar diameter to stock Model A.
30Murray is offline   Reply With Quote
