12-15-2018, 04:11 AM | #1 |
Radiator base dimensions for 1946 coupe.
Does anyone have the centre distance for the two mounting holes for the base of the radiator? My bracket holes measure 580mm apart which is too wide for the radiator that was in the car when I got it. The radiator was loose in the car so I’m not sure if it’s the radiator that is wrong or the way the brackets are set up.
12-15-2018, 10:21 AM | #2 |
Re: Radiator base dimensions for 1946 coupe.
Ab4875. I measured my '46 rad brackets and got 22.750", which is 578 mm. I could be off a mm or two, as the temp in my garage is -20C and the tape may have shrunk from the cold.
12-15-2018, 01:39 PM | #3 |
Measuring the 47 I get 22 1/4 inches with radiator mounted. Which is 565.15 mm
12-15-2018, 02:52 PM | #4 |
I get 22 1/2" on my '48 on a radiator that is out of the car.
12-15-2018, 05:56 PM | #5 |
