01-01-2013, 03:56 PM | #1 |
Speedometer gear housing endcap
Hello and a Happy New Year to Everyone. I`am having a dickins of a time removing the endcap off the speedometer drivegear housing. It is inthere so hard, I am just flaring the lip of the cap. I`ve used some "blaster" peneterating fluid and no luck. I would have broken several screwdriver tips if I had been to crazy working on it. Any thoughts as to what I might try next? Thanks
Richard/Maine |
01-01-2013, 06:15 PM | #2 |
Re: Speedometer gear housing endcap
Are you referring to the oval plate at the bottom of the Stewart Warner speedo?
Try this link to a thread https://www.fordbarn.com/forum/showthread.php?t=78422 I eventually found the plate easy to remove, by freeing the lip with a blunt Stanley knife blade and then engaging a small screwdriver blade under one edge and popping it out. If it absolutely won't come, it would be safe to drill a small hole, tap in a self-tapping screw and pull / lever on it with a Mole Wrench Or are you referring to the drive gear housing on the transmission tube? |
01-01-2013, 07:46 PM | #3 |
If you mean the "turtle"on the torque tube,I remove the end cap by drilling a small hole & pry it out with a punch.Then you can tap the shaft out towards the cable end.when its back together,use a drop of silicone to seal the hole to keep dirt out.
01-02-2013, 05:49 AM | #4 |
I am referring to the shaft retainer on the "turtle" on the speedometer cable end. The other end has an aluminum domed shaped plug.
Thanks Richard |
01-02-2013, 11:53 PM | #5 |
After removing the end cap,tapping out the shaft will bring the retainer with it.
01-06-2013, 08:57 AM | #6 |
01-06-2013, 11:19 AM | #7 |
If you don't want to use silicone you could solder the hole before re installing.
