Old 03-16-2014, 12:59 PM   #1
jim1932
jim1932's Avatar
Default Durable spray can paint?
Probably an oxymoran but what is the most durable way to spray or brush paint items like spare tire straps or tudor seat hinges. Yes I know powder coating will be most peoples answer, but I am specifically looking for something I can apply myself at home without a spray setup.
Thanks
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 03-16-2014, 01:06 PM   #2
Digger
Digger's Avatar
Default Re: Durable spray can paint?
When I rattle can stuff, I like Krylon, and it helps to do it in warm weather...
Digger is offline   Reply With Quote
Old 03-16-2014, 01:21 PM   #3
Charlie Stephens
I think the real auto paint stores can put anything you want in a spray can. They also sell (or used to sell) small sprayers with a small bottle and a can of compressed gas.
Charlie Stephens
Old 03-16-2014, 01:58 PM   #4
swedishsteel
I've used Rustoleum with good results. Takes a long time to get really hard but is tough once it does. Sprayed a spot about the size of a salad plate of Rusty Metal Primer on very front edge on an old Blazer hood--it was still there after several years and many thousand miles, never been washed, taking every thing from bird poop to road salt, 90 above and 30 below temps. That's what sold me on Rustoleem. Rod
swedishsteel is offline   Reply With Quote
Old 03-16-2014, 02:13 PM   #5
green50
green50's Avatar
Charlie Stephens
Yes, they still do it's made by a company called Prevail. It's a bottle that attaches to an aerosol can. It's sold at the big box orange store.
Gene
green50 is offline   Reply With Quote
Old 03-16-2014, 02:23 PM   #6
jim1932
jim1932's Avatar
Maybe I just haven't let the rustoleum sit long enough, but it seems to chip off on me.
Old 03-16-2014, 02:35 PM   #7
51 MERC-CT
51 MERC-CT's Avatar
Thanks
I have done similar items with brushed on POR 15 .
It can be thinned if necessary with a little lacquer thinner and when it's cured it has durability approaching that of powder coating.
Old 03-16-2014, 02:52 PM   #8
325w
Seymore brand spray paint is very good. Sprays better than Krylon before Krylon went to the Rustolemn formula.
325w is offline   Reply With Quote
Old 03-16-2014, 04:35 PM   #9
ct1932ford
ct1932ford's Avatar
Agree, best spray I have used. They have a Stainless Steel finish that is great and the Cast Iron finish is also good. Used the Black Lacquer also and had good results.
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 03-16-2014, 07:12 PM   #10
Russ/40
Russ/40's Avatar
Eastwood now has a special spray can that has an inner source to catalyze the paint. Same as paint with a catalyst. Expensive
Russ/40 is offline   Reply With Quote
Old 03-16-2014, 09:29 PM   #11
john worden
john worden's Avatar
Rustoleum has their hardware store line rattle cans and an automotive line. The auto line has auto type colors. I've used quite a bit of it. As with any paint though preparation is the key to an acceptable result. Good primers, correct sanding etc. are critical steps. I prefer to use these for interior parts and some under hood pieces.
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa.
john worden is offline   Reply With Quote
Old 03-16-2014, 09:49 PM   #12
uncle buck
uncle buck's Avatar
Zero Rust is available in spray cans and works great.
uncle buck is offline   Reply With Quote
Old 03-17-2014, 12:21 PM   #13
gunner
A lot of my small parts are taken to bare metal and then sprayed with Mercury Marine spray can primer.Probably on the expensive side,but I figured they have millions of outboards running in salt water and they don't seem to rust.If black I use there black spray over top.
gunner is offline   Reply With Quote
Old 03-17-2014, 12:28 PM   #14
34pickup
34pickup's Avatar
I don't remember the name but I used some epoxy in a spray can that gave a real hard surface. Just have to prepare the part for epoxy top coat first.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 03-17-2014, 01:59 PM   #15
sonny
sonny's Avatar
I use wrinkle paint. It holds up better than any other paint I have used. And using it for accessories, it looks great.
sonny is offline   Reply With Quote
Old 03-17-2014, 03:47 PM   #16
PeteVS
PeteVS's Avatar
Is that the "regular" Rustoleum or the "appliance epoxy" Rustoleum?
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 03-17-2014, 03:56 PM   #17
Bruce Lancaster
Most spray paints in my experience can be made MUCH more durable with a little heat. Oven is out, unless your divorce has come through...
I often balance small parts on top of a light bulb (old style) or lay them atop the exhaust pipe from my gas water heater for a while.
You want hot but not enough to burn...I think a bit upward from 200 is about right.
I have just purchased a cheap toaster oven because i am tired of parts falling off my makeshifts, and this will let me do things more easily and perhaps locate an optimum temperature.
You will be surprised at the increase in toughness after you heat a part.
Bruce Lancaster is offline   Reply With Quote
Old 03-17-2014, 06:35 PM   #18
jim1932
jim1932's Avatar
I have used the appliance paint. Not sure if it was "epoxy" That is what is chipping off the tire strap now and it isn't even on the car yet. Is the Eastwood undercarriage the right finish for seat hinges and spare tire straps? Not looking for gloss, but not flat either.
Old 03-17-2014, 06:57 PM   #19
B-O-B
B-O-B's Avatar
Dupli-color from Napa & or wally world
B-O-B is offline   Reply With Quote
Old 03-17-2014, 07:19 PM   #20
37 Coupe
37 Coupe's Avatar
Check out VHT black epoxy that stores like Advance Auto sells. I have used the very expensive Eastwood epoxies and Rustoleum and like this stuff the best.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
