Old 08-30-2015, 03:35 AM   #1
mike42
mike42's Avatar
Default '34 Over-Heating
Morning.....
A friend of mine recently purchased a '34 Roadster. He is having an over-heating problem and I was wondering if there is an inherent problem with the '34's doing this.
I want to say I read it somewhere on here, but can't remember the story.
Thx......Mike
mike42 is offline   Reply With Quote
Old 08-30-2015, 12:15 PM   #2
FL&WVMIKE
FL&WVMIKE's Avatar
Default Re: '34 Over-Heating
NO, Overheating is not something that you have to take for granted.
There will be a reason for it. There are several things that will cause it, a dirty radiator is , probably, the most common.
It might take an experienced hand to sort it out.
MIKE (mikeburch)
FL&WVMIKE is offline   Reply With Quote
Old 08-30-2015, 12:19 PM   #3
Charlie Stephens
It is probably the dirty radiator but timing and fuel mixture can also contribute to overheating.
Charlie Stephens
Old 08-30-2015, 12:22 PM   #4
CC33
CC33's Avatar
Charlie Stephens
As well as increase flow rate through water pumps. (ie, Skip)
CC33 is offline   Reply With Quote
Old 08-30-2015, 01:13 PM   #5
bobH
33-34's... Does this imply there might be some that DON'T overheat?
My experience has been as posted above - ie, partially plugged radiator.
My engine NEVER overheated, as long as there was coolant in it. Problem was, it would throw water out the overflow - radiator would not flow enough. Pressure valve helps some, too.
bobH is offline   Reply With Quote
Old 08-30-2015, 06:04 PM   #6
mike42
mike42's Avatar
Thanks guys. I appreciate the advice. I'll pass it on to him.
Mike
Old 08-30-2015, 07:13 PM   #7
Capt Kirk
Capt Kirk's Avatar
I haven't been around long enough to know but I would suspect that when these fords rolled out of the dealership on a 90-100 degree day they didn't overheat. To me, that says that the original design was adequate for cooling. After 80 years of service, I can understand that things aren't working as good as they did back then. Hell, Henry had no idea that his vehicles would be around for 100 years. Overheating is a symptom of some other problem. Clogged radiator, worn out water pumps, water jackets full of crap. If these components were reconditioned back to the state that they were in when they were new there would be no problems. 90 degrees in 1935 is the same as 90 degrees today. My overheating problem originated in the distributor...solve the cause and not they symptom.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 08-31-2015, 11:08 AM   #8
G.M.
Don't forget when these cars were new most people didn't drive very far like today.
Plus there wasn't much traffic, very few traffic lights and no global warming. In the late 40's I remember my 35 coupe and others running fairly hot but hot in those days was
when they boiled over once in a while. My guess NOW is the water was lost out the over flow and not replaced until it made steam. G.M.
www.fordcollector.com
