08-29-2015, 12:10 PM | #1 |
'39 3/4 ton Rear Brake Backing Plates
Dad & I have a '39 3/4 ton long term project. Every now and then we check our parts pile and just discovered we do not have rear backing plates. As near as I can tell from the Ford parts book the brakes shoes, components and E-brake cable are the same as '39-'41 car and commercial. The only listing I see for the backing plates is a part# 92Y 2213 &2214 for 122" trucks. The listing does not differentiate between 3/4 ton & 1 ton. Is this listing correct?
Which is the correct backing plate for a '39 3/4 ton? Any pictures would be a help also. Thanks Paul |
08-29-2015, 03:25 PM | #2 |
Re: '39 3/4 ton Rear Brake Backing Plates
AFAIK they are both 122" wheelbase trucks. I have never seen a 3/4 ton but I think they have the wide 5 bolt pattern as the '39 half ton. The One ton from '38-'47 has a 5 on 6 7/8 bolt circle and I think larger drums. Therefore maybe the 1/2 ton and 3/4 ton share backing plates. ??
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
08-30-2015, 10:22 AM | #3 |
I have a 47 one ton rear axle and a 41 3/4 ton rear axle at my Dad's shop. I won't be over there for about a month but I can take a look then to see if the backing plates are the same.
08-30-2015, 11:34 AM | #4 |
measure your drums inside dia. if it 12" a car backing plate will work, also does your trans have a parking brake drum on it ?, if not 3/4 ton , if it has it 1 ton
08-30-2015, 01:38 PM | #5 |
Thank you, that will be helpful if you could get a picture of the 3/4 ton rearend, we've looked at tonner rear axles.
08-30-2015, 10:56 PM | #6 |
Also on this page is a reference to the 3/4 and 1 ton handbrakes which are attached by a cable to the rear brakes with an under dash hand lever left of the steering wheel. There is some linkage on the backing plate and brake shoes that interact to make that happen. I have photos of that hardware if you need them. Les Williams |
08-30-2015, 11:13 PM | #7 |
PS: I noticed that the rear backing plate part# for the 122" trucks was different than the comm/car part#. This leads me to believe that they probably won't interchange. I suspect that the 3/4 and 1 ton axle flange is larger than the comm/car flange and has a different bolt pattern.
08-31-2015, 05:57 PM | #8 | |
Paul J. |
08-31-2015, 06:39 PM | #9 |
Have you tried a standard 39-41 passenger 12" backing plate on the 3/4 ton axle housing?
08-31-2015, 08:01 PM | #10 |
08-31-2015, 09:23 PM | #11 | |
08-31-2015, 11:26 PM | #12 |
The 3/4 ton was discontinued at the end of the 1942 model year. It reappeared in 1948, so your search includes '39-'42. Good luck and it would be great to see some pictures too.
09-01-2015, 02:14 AM | #13 |
"The 3/4 ton was discontinued at the end of the 1942 model year." Gary, it sounds like that memo didn't make it to the editors of the Green Book.
09-01-2015, 08:43 AM | #14 |
From what I read in the green book going by 1947 year, the 3/4 ton may have used the front plates. Does yours have the drive shaft parking brake? If so that might be the case, the front plates may have been used on the rear also.
09-01-2015, 01:05 PM | #15 |
"This year (1942) witnessed the last production of 3/4 ton ford trucks until 1948" James Wagner, from 'Ford Trucks Since 1905' page 208, 1942 section. It would stand to reason that a genuine ford publication would be more accurate than a book written about the trucks years later, even if Wagner is the official truck counsel for the Early Ford V8 club.
09-01-2015, 02:51 PM | #16 |
Les,
If you can find any info about the wrecking yard let me know. Thanks Paul J. |
09-01-2015, 07:30 PM | #17 | |
The phone number for the wrecking yard I have has been disconnected and there is no new listing. I asked my son-in-law who works for the SFFD to go by the site to see if its still there. He'll do this on Thurs and I'll get back to you. I also found some parts for the Tonner in CO [email protected]. They may have what you need. There is another option to consider and that would be to install a later model truck rear end (48-56). I saw a thread on that swap either on the EV8 or FTE sites. If you can get "Truck Dog's" attention who lurks on the Fordbarn, he can steer you in the right direction should you decide to go that route. Les |
09-02-2015, 09:31 AM | #18 |
Les, Thanks for the info. It'll be interesting to know if your son-in-law finds anything. I'll contact the CO email address also.
Paul |
