08-28-2015, 07:50 PM | #21 |
Re: 1932 V8 radiator
08-28-2015, 09:15 PM | #22 |
Take a close look before you trim. I think you will find that there is not enough threads on the rods before they go to a smaller diameter to let the nut slide over the rod. Kind of hard to visualize unless you are looking at one.
Charlie Stephens |
08-29-2015, 11:06 AM | #23 |
Charlie,
With respect, the diameter of the rods is 5/16" until the 3/8" threads under the head of the rod at the firewall end. A 3/8-24 nut slips easily over the 5/16" diameter portion of the rod. |
08-29-2015, 11:58 AM | #24 |
That is what I found out as well when taking a closer look at it. With it being a commercial vehicle, rods are not stainless.
08-29-2015, 12:25 PM | #25 |
They weren't originally stainless on any Ford of the era.
08-29-2015, 12:27 PM | #26 | |
What I was trying to say is that the 3/8 threads at the front near the radiator don't go far enough towards the rear of the car before dropping to the 5/16 rod diameter to allow you to cut off the rod. Looking again, it may be close and these threads may have extended further back on some rods. Charlie Stephens |
