11-10-2014, 09:09 PM | #21 |
Re: Running too warm
I bought mine from Speedway. Found a size that fit the radiator. Cut out the hole for the fan and mounted it to my radiator.
11-11-2014, 09:07 AM | #22 |
Bob, get a infra red gun,and check the temp all over your radiator,or use the old method with your hand, feeling your radiator for temp change. Also with the infra red gun check the top of each head for a difference in temp. I assume the fan belt is not slipping.Hope this helps.E.P.Williams
11-11-2014, 12:13 PM | #23 |
Bob,
I cant offer any advice as to the cause, but if you end up deciding to recore, I had my radiator done at Willards in Hudson, NH last year. They did a very nice job, split tanks as original. It was not inexpensive. But I do see that Drake is selling his 39 Dlx and 40 Radiator for 595. <if he has it... and shipping will bring you up to close to what I paid. Chris Chris |
11-11-2014, 02:15 PM | #24 |
In addition to containing the coolant, Skip's valve provides about 3 pounds of pressure in the system. This helps prevent "hot spots" by reducing steam pockets in the block. Vapor (steam) will interfere with cooling.
11-11-2014, 02:34 PM | #25 |
Performance of radiators drop off with age ,crud build up ect ,You can have it rodded out or do a Vinger wash if your core is in good shape you leave that in for two to three weeks then back flush it then fit a shroud ,(as suggested ) I used a plastic cut down Audi one from the junk yard ,in fact if you came to my place you will see that I have been to the junk yard a lot ..It should idol in the yard and not clime up the gage .Thermostats are only good if the radiator is over affiant ,eg to cold .If the radiator has restrictions in it then Skips product will force more water through and you will gain something .Ted
11-11-2014, 04:38 PM | #26 |
11-11-2014, 05:21 PM | #27 |
Bob if you look at most household fans its give s you a idea of how they work it stops the blades from dragging air in from the sides and creates a vortex ,the thing must be within 1/.2 of the blade tips ,covering at least 2 /3rds of the top part of the radiator or in the case of a split one most of it ,Don't over look the Vinger wash there are some post on here .Ted
11-11-2014, 06:07 PM | #28 |
I am interested in the comment about 195 degrees operating temp being desired. I have a stock 49 v-8 that was running 160 degrees with basic Stant 180 degree thermostats. Reading in other threads that higher temps were desirable, I changed to 180 degree Stant Superstats (45356) and now the stats open at about 190 degrees and drop to 175-178 degrees at hold there at all speeds up to 75 mph (lost my nerve there) uphill and down. Ambient temp today 45 to 70. The only way I see to get to 190 is to change to 195 degree stats. Is 175 degrees going to be a problem?
11-11-2014, 06:30 PM | #29 |
Looks like the WS 40 might work for you. These shrouds need to have the hole cut
out. Shrouds channel the air flow through the radiator, and less air from the surrounding area. http://www.walkerradiatorworks.com/R...plications.asp
Henry Ford designed the flathead without the aid of a computer. |
11-11-2014, 06:46 PM | #30 |
The purpose of the shroud is to have air drawn in from the entire surface of the radiator thus utilizing the full radiator area for cooling.
11-11-2014, 06:49 PM | #31 | |
11-11-2014, 07:57 PM | #32 | |
11-11-2014, 10:08 PM | #33 |
Make sure the ignition timing is correctly set and the point gap is to spec. Worn or closed points will set the timing back. If slow or retarded it will increase heating of the coolant.
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. |
11-12-2014, 09:06 AM | #34 |
41ford1, this was one of my first thoughts. I recently installed a newly rebuilt distributor and it was set just a tad different than when I sent it down. I did just a slight advance thinking that could be an issue. Engine runs fine and no "pinging" . I am a bit relieved to read a post above stating high temps are better. maybe I'm just an old worry wart ? Nice to get so much discussion on the subject. Thanks to all
11-12-2014, 09:45 AM | #35 |
Just picked up a fine infrared thermometer on Amazon for less than $20....Does the job of tracking those temps.
