Old 10-16-2023, 05:50 PM   #1
48fordconv
Default 48 Ford how much play on rear driveshaft yoke
I have a 48 Ford that converted to open driveshaft. How much play up and down on the yoke, Thanks Steve
48fordconv is offline   Reply With Quote
Old 10-16-2023, 07:17 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 48 Ford how much play on rear driveshaft yoke
Steve ..... Let's see if I understand your question. Are you talking about grabbing the yoke and physically moving the yoke (and the pinion shaft) literally up & down in relation to the banjo housing? If that's what you're asking, and that's what it's actually doing, that's bad news! That shouldn't have any up & down play.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 10-17-2023, 08:08 AM   #3
48fordconv
V8COOPMAN
What do you think is wrong ? Noticed grease seal was leaking
Old 10-17-2023, 10:41 AM   #4
Mart
Mart's Avatar
Lock nuts have probably worked loose. There is a specific tightening method for these. They need to be not too tight in clamping down, but tightly locked together.
Old 10-17-2023, 05:15 PM   #5
48fordconv
Mart, Which lock nuts.
Old 10-17-2023, 06:18 PM   #6
Brian
Brian's Avatar
Which yoke? Out back of the transmission- the sliding yoke?
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 10-17-2023, 06:34 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
Your OPEN DRIVE should look like this first picture. Once you remove the SIX BOLTS and the cover where the pinion goes into the banjo housing, you should see the two lock nuts as seen in the 2nd picture below.
The two lock nuts seen in this picture. They lock against each other with a French lock between the two nuts.
Coop
T5 W/TORQUE TUBE
Old 10-18-2023, 09:39 AM   #8
48fordconv
Brian, the yoke coming out of rear end with open drivesalf
Old 10-18-2023, 10:33 AM   #9
jimvette59
jimvette59's Avatar
You should have NO play up and down or in and out.
jimvette59 is offline   Reply With Quote
Old 10-21-2023, 08:17 AM   #10
Rodrelic
Drag should be something like 1.7 in # I thought, rather than toggle something up I elected to do it by “ feels good” that is enclosed, but same thing. If it feels gritty, I would pull it out & change cup & cones. Really not good if bearings spun & wallowed out housing.
Rodrelic is offline   Reply With Quote
Old 10-21-2023, 01:38 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
Really not good if pinion was able to move up & down and left & right while driving against the ring gear and totally eating the ring gear up! Ring and pinion are probably junk.
Coop
T5 W/TORQUE TUBE
