12-17-2011, 04:29 PM | #1 |
Oil Capacity Question
My FoMoCo 49-51 Mercury V-8 Overhaul Manual says the following re: crank case capacity:
Engine Oil: DRY (including filter).......6 qts. REFILL..........................5 qts. I interpret this to mean that when changing both the oil and the filter you refill with 6 quarts. But when you REFILL without changing the filter you refill with 5 qts. Am I correct? Thanks. |
12-17-2011, 05:36 PM | #2 |
Re: Oil Capacity Question
I'm confused about this; my 59L has a MCF full flow oil filter kit on it and if i put in 6 quarts, it shows over full. The level on the dipstick settles at the factory full mark with 5 quarts after an oil change. I agree with what your interpretion of the factory manual for your motor, maybe there is a difference in pan capacities between our motors? I got the same info out of the manual for mine.
Rich |
12-17-2011, 05:48 PM | #3 | |
12-17-2011, 05:58 PM | #4 | |
