02-03-2022, 02:25 PM | #1 |
Oil change surprise !
I changed the oil and when I was cleaning out the drain plug I found a small pice of copper. It looks like a shim stock. I have about 30K on the engine. It runs fine no knocking or tapping. Shall I be alarmed?
Thanks
31 Tudor 66 Bonneville 57 Chevy pickup 27 T roadster pick up |
02-03-2022, 02:42 PM | #2 | |
Re: Oil change surprise !
Maybe a picture will help us before people start guessing? Last edited by Y-Blockhead; 02-03-2022 at 02:47 PM. |
02-03-2022, 02:50 PM | #3 |
OK, I see. Bratton's has steel or brass shims.
https://www.brattons.com/BRASS-CONNE...ductinfo/8650/ |
02-03-2022, 08:44 PM | #4 |
if it were mine i would worry about it, but thats the way i am.
and if it was mine i would pull the pan and have a look. i would be able to sleep, that thought on my brain.
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
02-03-2022, 08:46 PM | #5 |
picture of the piece?
02-03-2022, 09:30 PM | #6 |
02-04-2022, 06:36 AM | #7 |
Worth dropping the pan for a look see for sure. That's why God gives us winter... Chap
02-04-2022, 08:11 AM | #8 |
Worth a look. After 30K miles it is time to take up the bearings anyway. This is a maintenance task on an engine that has babbett bearings.
02-04-2022, 10:10 AM | #9 |
I don’t have a picture. The pice got tangled up in my shop rags and thrown out I thought of taking when it was to late. Now I have fresh oil in. Before I get involved I’m going to put a few miles on and watch and listen! It’s definitely on my mind
02-04-2022, 11:55 AM | #10 |
By the time you hear anything, it might be too late.
02-04-2022, 12:48 PM | #11 |
You know ..your right! I’m going to drop the pan. Hopefully I just have to make some adjustments and don’t get the domino affect. I will feel better once I take a look
Thanks everyone!
02-04-2022, 01:26 PM | #12 |
Is there a chance somebody put 1 of those copper Brillo pads in the oil filter tube maybe just a small fragment in 1 of those if so it's nothing to worry about
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
02-04-2022, 09:52 PM | #13 |
Some oil drain plug gaskets are made of copper. Was the piece circular in shape?
02-05-2022, 10:17 AM | #14 |
It didn’t look like a pice of the drain plug. It definitely was outside the edge of a shim. I wish I got a picture of it!
02-05-2022, 11:15 AM | #15 |
I may be wrong, but I thought the shims were brass
02-05-2022, 12:07 PM | #16 |
Is the engine lubrication system stock? Or modified?
02-05-2022, 02:28 PM | #17 |
Please don’t try to fix something that might not be broken.
It was running good before you drained the oil. How is it running now? If still running and sounding great? Drive and enjoy you car. People spend a lot of money fixing things that don’t need to be fixed. Enjoy. |
02-05-2022, 02:36 PM | #18 |
I believe in not fixing stuff that isn’t broken, but would at least drop the pan and have a good look. This would be a good time to check the bearings too, and check everything else. Who knows, whoever was in there before might have left something.
02-05-2022, 02:37 PM | #19 |
Any grandchildren helpers?
02-05-2022, 03:53 PM | #20 |
Yep …..you read my mind. I have 2 grand sons. It’s going to be a good learning experience after 30k i think it time to take a look anyhow
My A is a great car. For 25 years it’s been turn key and go
