Old 11-18-2015, 09:46 PM   #1
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Cool Ron rude: length of horn wire
Ron I burned my 6volt horn out, probably from the replacement horn cover screw. I was going over the horn threads from the past and wondered if you(or anyone else) knows the approximate length of the 20 gauge wire. A motor shop I use a few miles away has the wire, but unless I unwind, if possible, the windings, I don't know how much I need. This will be a new experience for me,but seems relatively easily. Tia. Chuck
Old 11-18-2015, 10:36 PM   #2
Ron in Quincy
Ron in Quincy's Avatar
Default Re: Ron rude: length of horn wire
Chuck,
6 Volt Horns:
(1) the 2 field coils are wound in opposite directions.
(2) Original field coils wire is 20 gauge.
(3) a. 45turns using coated wire.
b. 6 to 7 turns per layer, not perfect is ok.
(4) after completing, spray with varnish or insulating enamel.
If you need the armature re- wound, contact Jim Diehl in Cadillac, MI,
his e-mail is: [email protected] .
He also will rebuild the horn, need the complete horn, he rewinds the fields and armature, installs a bearing in the motor housing for the armature, replaces the brush holders, connectors, and gaskets if needed, guarantee for 1 year. I do not know what his prices are as it has been quite some time since I last talked to him.
Ron
Jim Diehl is the one that gave me the gauge, He also gave me the info for a person who wnts to wire his horn for 12 Volt.
Ron in Quincy is offline   Reply With Quote
Old 11-18-2015, 11:21 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I've rewound a couple sets of horn fields, and I posted the size and length of the wire here, but that might have been back when Shelly owned Fordbarn, so it might not turn up with a search. I don't recall the length, but was thinking it was about 20 feet.
Old 11-19-2015, 12:08 AM   #4
daveymc29
daveymc29's Avatar
Thought I read that the wire is supposed to be 23 gauge wire? Not correct?
daveymc29 is offline   Reply With Quote
Old 11-19-2015, 08:00 AM   #5
Slowplane
Slowplane's Avatar
see thread: Sparton Field Coils
______________
Nothing Short of Right is Right
Slowplane is offline   Reply With Quote
Old 11-19-2015, 08:17 AM   #6
burner31
burner31's Avatar
Same thing happened to me, I went to the shop to get some wire and the kid asked me how long am I'm going to need it?
I told told him I'm hooking up my headlights so I'm going to want it for quite awhile.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 11-19-2015, 11:16 AM   #7
Skeezixx
Skeezixx's Avatar
Funny. I have to remember this next time.
Skeezixx is offline   Reply With Quote
