05-15-2011, 11:37 AM | #1 |
Rear Wheel Bearing Update
I think Kube is correct . It looks like having my axle housings cleaned using the Redi Strip process has took away the hardness of the bearing races . I went out this morning and run a flat file against a pair of housings I am about to use in my 39 LZ Coupe that I just had cleaned and the file will cut metal when run across the bearing race.I then did it on an original housing and the file will skate across the surface. Now I will have to send my housings to have them resleeved. Huge lesson learned here. Like my Dad always told me,"there aint no lesson like a bought lesson".
05-15-2011, 07:16 PM | #2 |
Re: Rear Wheel Bearing Update
I didn't think Redi Strip did anything hot enough the anneal hardened steel! At least you won't have to anneal them to turn them down for fitting the sleeves.
Don't never get rid of nuthin! |
05-15-2011, 07:17 PM | #3 |
Thanks for the info Ken.
Chisel |
05-16-2011, 07:24 AM | #4 |
Ken,
Since you're talking rear axles here maybe you can help me with my "problem". I have a stock 40 rear axle that doesn't vent and because of that, it constantly drips from the drain plug. I have had all kinds of explainations of how they are supposed to vent and have looked in vain for the answer in the green bible but can't find out for sure. All I know is; I'm tired of the mess and would like to get it fixed before driving to BG, Ky in mid-June. Any advice is appreciated. Thanks, Rich |
05-16-2011, 08:23 AM | #5 |
Some people drill a 1/16" hole in the center of one of the upper banjo-to-bell bolts as a vent. Be sure its one at the top. Hope this helps.
05-16-2011, 08:42 AM | #6 |
05-16-2011, 08:55 AM | #7 | |
05-16-2011, 10:30 AM | #8 |
Thanks for quick answer. It is definitely building up pressure because even after a short drive, I pull the fill plug and it almost jumps out of the housing with big whoosh of pressure expelling. So far no lube out the axles so I wanted get this fixed before the problem got any worse.
05-16-2011, 11:05 AM | #9 |
After you get those axle housing bearings repaired you may want to consider packing the roller bearings with Sta Lube Heavy Duty Drum Brake Bearing Grease, part number SL3131, marketed by CRC Industries. As noted on the 14 oz. container, this is a "traditional short fiber" grease. This is probably better than a modern "no fiber" grease for these bearings. I found it at a Western Auto store. You could also order this on the internet.
05-16-2011, 01:21 PM | #10 |
There are axle sleeves out there that are imported and a lot of them are junk. Be sure you buy US made sleeves. The stripping process should have no ill effect on the races. Look closely at the end of the race. You may see where it has been sleeved in the past, with inferior sleeves.
05-16-2011, 03:35 PM | #11 | |
