10-18-2023, 12:46 AM | #1 |
Are These Model A Parts?
Been sorting through some boxes that were collected decades ago by my dad for my 29 RPU. Most I have figured out but there a couple that I'm not sure about. There have been a few 56 F100 parts mixed in. #1 and #2 look similar but they are not. #3 was sealed in bag and appeared a new part.
10-18-2023, 02:18 AM | #2 |
Re: Are These Model A Parts?
#1 and #2 are hood rod brackets
#3 A3519 is a steering column support bracket |
10-18-2023, 03:22 AM | #3 |
Thanks Bob. That's what first came to mind with #1 and #2 but wasn't sure. I'm assuming they mount flat side up under the cowl lip. Do they not match side to side? Are these the correct ones for '29?
10-18-2023, 07:22 AM | #4 | |
They mount flat side down onto the cowl area just behind where the cowl lacing is installed. |
10-18-2023, 10:16 AM | #5 |
The hood latch brackets use flat or oval head screws into captive 12-24 nuts in the cowl. I've seen all manner of workarounds since the 12-24 isn't a commonly available size in your average hardware store or big box DIY. Hint - it is NOT a 10-24!
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
10-18-2023, 04:17 PM | #6 |
10-18-2023, 05:35 PM | #7 |
They’re there on USA made cars (cage nuts)
Dunno about exports |
10-18-2023, 06:41 PM | #8 |
10-18-2023, 07:08 PM | #9 |
You can also get them from the usual Model A vendors.
10-19-2023, 02:30 AM | #10 |
10-19-2023, 10:02 AM | #11 |
Not sure about the Hood Retainer Cage construction of McMaster's Cage Nuts, but speaking from experience on restoring Windshield Filler Trim, do NOT use the 5/16-24 Cage Nuts that McMaster Carr carries. There is a punched flange on the bottom that must be removed for the cage to sit flat. Also, the cage is not accurately bent requiring some time to make those correct.
I think the next time I will make the cage frame using a CNC plasma and make a set of dies to bend the cage. |
