01-24-2012, 04:32 PM | #1 |
what finish to use on my pickup bed
Hi, I bought a new Brookville pickup box for my 1930 roadster pickup at Hershey this fall, from what I understand the wood originally was painted the body color, i want to have a natural finish and am wondering what everyone used for the finish and to seal and protect the wood so it will last, also how many coats, Thanks
01-24-2012, 04:37 PM | #2 |
Re: what finish to use on my pickup bed
I used several coats of good polyurethane varnish from Home Depot. I did not stain.
I also like and used the stainless rails. |
01-24-2012, 04:43 PM | #3 |
I used Minwax Colonial Maple stain & Minwax Satin Urathane. Wood is red oak.
The pursuit of excellence is healthy and rewarding. The pursuit of perfection is frustrating, neurotic and a terrible waste of time. |
01-24-2012, 04:51 PM | #4 |
I just put the bed on my 39 pickup. I sanded the wood, sealed it, then put two coats of Minwax gloss polyurathane (sanded in between) for a natural wood finish.
01-24-2012, 05:30 PM | #5 |
Mine has a natural wood finish, top and bottom.
01-24-2012, 05:39 PM | #6 |
01-24-2012, 08:44 PM | #7 |
I agree that your best finish will be obtained by removing the oak slats from the pickup bed and finishing them individually out of the bed. I've had good luck using automotive clear in order to give a nice finish coat on natural (or stained) wood finishes. I've used this on a '29 mail truck project, the spokes on a Model T project, and all of the floor sills on my current '29 Briggs Town Sedan project - great appearances to all. As far as the number of coats, I would suggest a minimum of at least three, taking care to water sand in between coats and adding additional coats until all of the grain is completely filled and you get a completely smooth finish. Just my thoughts, but this has worked well for me. We also did this on my nephew's '28 roadster pickup, which received a first in the Touring Class at the national meet in French Lick in 2010. That project was finished six or seven years ago, has held up well, and still looks good.
Best of luck whatever direction you choose to go. Dick |
01-24-2012, 08:53 PM | #8 |
Thanks for the replies I did wash the bed , used self etching primer, then put on epoxy primer getting ready to paint (duchess blue) , I do have the wood out to get all of it I was curious if there was a particular brand or type of polyurathane to put on also what grit to sand between coats, thanks again for all the input I really appreciate all the help I get here!!!!!
01-24-2012, 09:59 PM | #9 |
I went the polyurethene route on top, and painted the underside with 3-4 coats of black enamel
I used steel bed strips painted body color, with stainless steel carriage bolts |
01-24-2012, 10:09 PM | #10 |
There is a marine product called Epiphani (sp?). This is made for boats that are out in the weather and I've been told is an excellent product. Some Model Aers have used it on their woodies with good longevity. I believe it's about $30./quart.
I plan to use that product on my pickup this winter. Original wood had a black preservative on all sides, then installed and painted body color. |
