Old 08-08-2015, 10:45 AM   #1
Chuck Kuntz
Default Common Rust problems on 1951 Ford?
I am looking at a 1951 Ford and wonder what are the common rustout areas to look for the than rocker panels, fender bottoms, headlight areas etc. Thanks for any help.
Chuck
Chuck Kuntz is offline   Reply With Quote
Old 08-08-2015, 10:57 AM   #2
corvette8n
corvette8n's Avatar
Default Re: Common Rust problems on 1951 Ford?
My 1950 was rusted in the drivers floor, I also has to run a ground directly to the front directional socket to get them to work properly, must have been just enough rust/corrosion around grill and body to inhibit the ground.
Old 08-08-2015, 10:57 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
You pretty much named them all with the exception of all the floor panels.
Depends also what climate it resided in.
Old 08-08-2015, 12:11 PM   #4
46ford
46ford's Avatar
All the body mount areas. Rear of the trunk floor. The frame.
I lucked out with mine.
46ford is offline   Reply With Quote
Old 08-08-2015, 12:59 PM   #5
TJ
TJ's Avatar
Check the front edge of the hood. They commonly rust there also.
Old 08-08-2015, 01:04 PM   #6
34PKUP
34PKUP's Avatar
Really simple, any part that's made out of steel.
34PKUP is offline   Reply With Quote
Old 08-08-2015, 02:41 PM   #7
my4dv8
Rear pan, chassis outriggers, bottom of The A pillars , rear wheel arch lip, inner sills.
Take a good torch with you.
my4dv8 is offline   Reply With Quote
