05-22-2010, 08:22 AM | #1 |
40-41 cowl vent question
Does any one have a photo or diagram of the correct placement of the nut/washers on the cowl vent mechanism, 40-41 P/U. I took the vent apart to put in new rubber and I must have gotten the small parts back in incorrectly. The vent will not close tightly nor will it open correctly.
Any help would be appreciated. |
05-22-2010, 01:08 PM | #2 |
Re: 40-41 cowl vent question
I had that problem with mine, but I figured it out. I can take a picture tomorrow if you like.
05-22-2010, 01:10 PM | #3 |
I have a 41 sedan and will check for you. I replaced the seal several years ago
and dont remember any problems. John |
05-22-2010, 01:38 PM | #4 |
Hey Cecil, I'm in the same situation as Mark. I looked in the shop this AM to see if I could help Mark out. Unfortunately all I have is a disassembled bag of parts. If you would be kind enough to send me a picture as well, I'd appreciate it. Thanking you! Dennis/Arkansas
05-22-2010, 02:32 PM | #5 |
Recently replaced the rubber seal in my '47 and found the seal to be too thick, otherwise the shape was correct as purchased from Mac's. Good Luck: Fred A
05-22-2010, 05:36 PM | #6 |
Make sure you have the correct hardware. They are shoulder bolts and special washers. I have one set left. |
05-22-2010, 08:54 PM | #7 |
Thanks, the seal is fine but the cover wont come close enough to the closed position, also some times wont open all of the way. I must have the washers on in the wrong positions. Forgot to take photos before I dis-assembled it.
05-23-2010, 10:48 PM | #8 |
This might help you out! |
05-23-2010, 11:29 PM | #9 |
05-24-2010, 07:07 AM | #10 |
I am attaching some pictures of the cowl vent on my pickup. I hope they show what you need.
05-24-2010, 07:55 AM | #11 |
