Old 02-02-2011, 10:37 AM   #1
Don
Don's Avatar
Default oil pump in 59ab
How do i tell if i have a 50# or 80# oil pump. And is there any thing special to do to the relief spring ,everything looks good and gears or not worn and bushing is tight on shaft. Dp
DON P
Don is offline   Reply With Quote
Old 02-02-2011, 11:53 AM   #2
JWL
Default Re: oil pump in 59ab
Does the pump have helical (twisted) gears, or straight teeth? The 80lb. pump has "twisted" gears.
It probably won't hurt anything to put 1/16 shim behind the spring of the relief valve.
JWL is offline   Reply With Quote
Old 02-02-2011, 12:46 PM   #3
Don
Don's Avatar
I have straight gears about 1/1/2 long must have a 50# ok on the shim dp
DON P
