Go Back   The Ford Barn > The Swap Meet > For Sale > Late V8
Old 02-12-2015, 07:25 PM   #1
gearhead1952
gearhead1952's Avatar
Default Autolite 4100 Carb 4BBL 1.12
City: Arvada
State: CO
Price: 225
This is an Autolite 4100 carb in good shape that I took off a 1966 289 A code motor. Ran fine just too big a carb for the A code motor. Has the 1.12 venturi which is 600cfm. Was rebuilt with a kit from Mike's Carbs including new floats and idle mixture screws. Carb was very clean inside and did not need a rebuild. I will give you all the old parts removed. Has Pri Vent #1 / Sec Vent #6 / Pri Jet 65 / Sec Jet 53
The one pic shows the area where there should be numbers stamped to indicate application but there is only the letter P which makes no sense. From my research I believe this to be from 1963 or 1964. The tag was missing from the top when I got it.
Price is $225 plus shipping.
gearhead1952 is offline   Reply With Quote
