11-28-2014, 05:43 PM | #1 |
Flathead bell housing
I need some information on bell housings. I have what I believe is a 8ba But I need to mount a 39 trans behind it. I have one bell housing now but it doesn't line up on the block side. I will attach some pictures here
11-28-2014, 05:46 PM | #2 |
Re: Flathead bell housing
Here is one picture
11-28-2014, 05:48 PM | #3 |
This is the block
11-28-2014, 06:00 PM | #4 |
What doesn't line up on the block side? That looks like the BH you would need.
'52 F-1, EAB flathead |
11-28-2014, 06:18 PM | #5 |
I had another guy look at it but still worn line up.
11-28-2014, 06:19 PM | #6 |
11-28-2014, 06:28 PM | #7 |
Your bell isn't for a flathead V8. Take a picture directly above showing the block mount pattern and maybe we can ID the bell.
11-28-2014, 06:40 PM | #8 |
This is the top picture.
11-28-2014, 06:45 PM | #9 |
Does anyone have one that would work for me for sale?
11-28-2014, 06:46 PM | #10 |
I think that's for a 6cyl.
Bob |
11-28-2014, 06:52 PM | #11 |
It's a 6 cylinder truck bell housing.
11-28-2014, 06:55 PM | #12 |
Okay thank you, I appricate the help.
If anyone has one for sale please let me know |
11-28-2014, 06:56 PM | #13 |
11-28-2014, 08:12 PM | #14 |
Trucks all had cast iron BH's AFAIK
11-28-2014, 08:20 PM | #15 |
That may be for the Lincoln 337 flathead.
11-28-2014, 08:33 PM | #16 |
Make sure you get a cast one from a truck if you want to run an 11 in. clutch. The stamped steel ones from a Merc won't take the bigger clutch. Also, make sure you get the correct starter plate for the housing.
Making the simple complicated for over 30 years. |
11-28-2014, 10:44 PM | #17 |
Here is a link below to some bells and starter plate combination pictures.
http://www.flatheadv8.org/bellhousing.pdf .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
11-29-2014, 11:10 AM | #18 |
1966: Be sure and read every single word in the thread below including all the links in the thread. Do this and you will have all your questions answered. I installed an 8BA engine and a 10 inch Ford pressure plate and clutch in my 40 45 years ago and it's still working fine. The same method applies to the 39. The anti-chatter rods set up has to be modified also. If you use the 1949-51 Merc stamped steel bellhousing with matching starter plate you can use the 10 in clutch. 11 in. clutch is overkill.
https://www.fordbarn.com/forum/showth...engine+40+ford Last edited by 19Fordy; 11-29-2014 at 11:20 AM. |
11-29-2014, 01:20 PM | #19 |
That is from a truck 48-51 226 bellhousing.
