Old 12-10-2019, 09:42 AM   #1
professorpat
Default 1+ton heavy duty truck wire wheels.
I have found a set of split rim heavy duty Model A truck wire wheels, with hub caps. I have only seen one other set in my sheltered life. Value?, rareness?
professorpat is offline   Reply With Quote
Old 12-10-2019, 10:59 AM   #2
Truckerjim
Default Re: 1+ton heavy duty truck wire wheels.
Split ring or split rim . Split rim are dangerous ,do not use . Split ring are also dangerous but if done properly are not as bad . Know how to work on either type or take to truck tire place were they have proper tooling and safety cage.
Truckerjim is offline   Reply With Quote
Old 12-10-2019, 11:45 AM   #3
Bob C
Are they for a 1928 or 1931, how about a picture.
Bob
Bob C is online now   Reply With Quote
Old 12-10-2019, 01:37 PM   #4
professorpat
Yep, split ring
Old 12-10-2019, 01:38 PM   #5
professorpat
As far as pictures...Will get a couple
Old 12-10-2019, 03:09 PM   #6
WTSHNN
WTSHNN's Avatar
1928's used a wire wheel
In 1931 a Deluxe wire wheel was also available.
All images are from aafords.com
-Tim
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
