Old 04-09-2013, 10:20 PM   #1
SteveM
Default Ratchet nut
My ratchet nut must be worn. The edges on it are not as sharp as a new one (I have a new one in my parts box). The crank slips out easily if I'm hand cranking it.
There's not much room in front of the engine - is it possible to change the ratchet nut without removing the radiator?
I can't find my copy of Les Andrews' book, so I can't look it up.
Steve
SteveM is offline   Reply With Quote
Old 04-09-2013, 10:32 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Ratchet nut
Yes, it's easy. I made a special box wrench by heating a combination wrench and putting a couple bends in it. If you can slip a socket over the nut and a breaker bar, just lay it on the driver's side of the frame and hit the starter for a split second with the key OFF. This will break it loose. I do the same thing with my box wrench. Slick and easy.
Old 04-10-2013, 12:02 AM   #3
columbiA
If thepin in the hand crank has flat spots worn on it,it may even slip on a good crank nut.Crank nut also needs to line up with hole in crank brg.
columbiA is offline   Reply With Quote
Old 04-10-2013, 02:33 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
The Dog just learned the words, RATCHET NUT, he's LAUGHIN' & he just called me a "RATCHET NUT"-----What's a man to do??? Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-10-2013, 02:43 AM   #5
Drive Shaft Dave
Smile Re: Ratchet nut
Well Bill you are just A nut!
Drive Shaft Dave is offline   Reply With Quote
Old 04-10-2013, 07:50 AM   #6
SteveM
Thanks. Looks like I"ll have to hit the flea market for a 1-3/8" wrench.
Steve
Old 04-10-2013, 10:17 AM   #7
CarlG
CarlG's Avatar
I found an 1-3/8" short socket, 1/2" drive that I use (on eBay). It just fits, then run a 1/2" extention thru the crank hole & use your favorite breaker bar or ratchet wrench.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-10-2013, 01:46 PM   #8
junk yard kid
I found that a vw axle nut socket will also work I think 32mm. Its wrong but it works. I use a long extension and a electric impact to take mine off.
junk yard kid is offline   Reply With Quote
Old 04-10-2013, 02:25 PM   #9
Rock Hornbuckle
Rock Hornbuckle's Avatar
A friend of mine had a girlfriend that was a wing-nut. Is that the same thing?
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
