09-24-2016, 02:30 PM | #1 |
Sway bar help
Hi guys, need help with the sway bar form shoebox central that I rec'd. No directions at all and it is much shorter on the bent ends than what's in the car now. 1950 Merc. Kit comes with "L" brackets, bolts with sleeves and a bunch of hardware, square tubing, etc. I called Shoebox and they aren't open on Sat. Anyone have a diagram that might help me? Thanks, old guy Rich.
09-24-2016, 03:26 PM | #2 |
Re: Sway bar help
The kit in effect alters the original system. The stabilizer can no longer attach to the suspension in the same location. The new links have to attach to the lower control arm but I'm not sure exactly where. The links are usually mounted vertically from the control arm up to the end of the stabilizer bar. Some of this stuff is more geared toward modified suspension set ups utilizing control arms & spindles from other later designs or dropped spindles. I don't know of any large diameter stabilizer bars that are a direct fit to the OEM suspension components.
It looks a lot like the one JAMCO has. http://jamcosuspension.com/products/...D2/80/sfID3/15 Last edited by rotorwrench; 09-24-2016 at 03:38 PM. |
09-24-2016, 04:45 PM | #3 | |
Re: Sway bar help
All it should take is simple directions where to drill the holes, maybe a template. Thanks again. old guy |
09-24-2016, 06:13 PM | #4 |
Re: Sway bar help
They probably add that stuff to aid in the alteration if needed. There is no place on most cars to level the frame out using hydraulic jacks but if a person could do that then they could use a plumb bob hung from the bolt hole in the tip of the bar down to the A arm frame to get a relatively accurate location to drill the hole. To be right truth full, I don't know if it would really have to be all that accurate though. Keep in mind, these things were made by folks to solve a problem and I don't know how much "engineering" went into the process other than garage engineering. Many of these old Mercs are being modified to lower them and such and there aren't enough of them out there for these Fab Shops to really cash in on. Fat Man and Chassis Engineering make a lot of stuff for this and one of them may have made these parts but I can't tell you for certain.
09-24-2016, 06:28 PM | #5 |
Re: Sway bar help
Thanks rotowrench, I'll just wait til Monday and call to see if they have a template. I can eye-ball it if they have no instructions or templates. old guy.
09-25-2016, 08:40 AM | #6 | |
Re: Sway bar help
09-25-2016, 09:19 AM | #7 |
Re: Sway bar help
Just looked at Shoebox Central, http://shoebox-central.com/1949-1950...i-roll-bar-new
The use a different arrangement with short links. |
09-25-2016, 01:50 PM | #8 | |
Re: Sway bar help
