10-03-2011, 08:31 AM | #1 |
Power gen and fan pulley
Anyone running a Power-Gen with the fan mounted pulley? I would like to put one on my 32 v8 but not sure if the pulley fits and will the power-gen handdle the load. I also think the Fan pully is larger dia. than the one on the Power-Gen.
10-03-2011, 11:57 AM | #2 |
Re: Power gen and fan pulley
ive heard nothing but bad things about powergens. apparently they go bad quick from overheating.
10-03-2011, 12:20 PM | #3 |
I have been running one for two years with no problems. Speedway sells a pully that mounts the fan to it.
10-03-2011, 05:06 PM | #4 |
Thanks! anyone else?
10-03-2011, 05:32 PM | #5 |
I'd recommend either the new, reasonably-priced 3-wire 10si clone from http://www.dbelectrical.com/c-8468-110-amp.aspx or the 1-wire http://www.dbelectrical.com/c-8471-110-amp.aspx. I prefer the 3-wire, which can also easily be set up as a one wire by connecting the #2 sensing terminal directly to the output, and leaving the #1 exciter terminal open. The 1-wire setups usually require an rpm bump to get things charging.
As for the fan mount, I use a 3"x3" square of 1/8" steel flatstock mounted between the alternator rotor nut and pully with fan screws at each of the 4 corners. Jack E/NJ |
10-03-2011, 07:03 PM | #6 |
10-03-2011, 07:32 PM | #7 |
I have a one wire alt now(6 v-pos) with fan pulley. I ran an exiciter wire that i have on a toggle so not to have to rev it up to charge. Everything works fine I just wanted the Generator look for my car being a very traditional roadster. Thanks.
10-04-2011, 03:55 AM | #8 |
ive had a powergen for 18 months no problem so far, i think early ones were suspect. bought a pulley to suit the stock fan fits fine.
