Old 10-14-2010, 12:17 PM   #1
1936coupe
1936coupe's Avatar
Default started part 4
connected tyre pump to fuel line it blew back to tank removed blockage, then no prob car running fine, note to self do not run out of gas. thanks for all replys.
1936coupe is offline   Reply With Quote
Old 10-14-2010, 12:29 PM   #2
PeteVS
PeteVS's Avatar
Default Re: started part 4
Gotta be careful here. If you blew something back into the tank, it's just sitting there waiting to be sucked back into the line. All kinds of interesting things wind up in a tank- kids deposit band aids, tank linings break up....
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 10-14-2010, 12:46 PM   #3
1936coupe
1936coupe's Avatar
yep did think that but car never much left on street so dont think anything been put in there, prob just rust/ sediment dragged in with low fuel,see how it goes hope ok!! will see, if more trouble then tank out.
Old 10-14-2010, 01:02 PM   #4
weemark
glad to hear it vic, does sound like you have something floating about inside the tank though. maybe one to sort over the winter.
weemark is offline   Reply With Quote
Old 10-14-2010, 01:33 PM   #5
gmc1941
gmc1941's Avatar
If you can drain your tank from the bottom theirs no gurantee that you drained all the crap out of the tank. I've found out the hard way, that a lot of the rust is from the top of the tank. Unless you get the tank boiled out it will happen again again again and again. After cleaning it out, coat it with a tank sealer.
1939 Fordor Deluxe
1939 Ford Coupe Std
1940 Ford pickup
Nothing in life is to be feared; it is only to be understood.
gmc1941 is offline   Reply With Quote
Old 10-14-2010, 06:41 PM   #6
19Fordy
19Fordy's Avatar
Not trying to spend your $$$ but save yourself some heartache and install a nice new tank. Peace of mind is priceless.
Old 10-14-2010, 07:34 PM   #7
1936coupe
1936coupe's Avatar
with you there. maybe a winter project!!
