Old 06-04-2012, 12:45 PM   #1
1936coupe
1936coupe's Avatar
Default reds headers
went to fit some reds headers today but could not quite get them in. only tried driver side so far. looks like i will need to jack up engine to get it in (prob 1/2" or so?), how far can you jack it? will chatter bars need removing, gearbox mount etc. any other probs to look out for? thanks.
1936coupe is offline   Reply With Quote
Old 06-04-2012, 01:04 PM   #2
Scott H
Scott H's Avatar
Default Re: reds headers
I had mine bolted to the engine when I was putting the engine on the frame. The passenger side wanted to hit the frame so I took that side header off. Set the engine down and then bolted the header back on. I don't have any problem taking them off and putting them back on without having to move the engine, the chatter rods, or the starter. Its a 36 pickup body but I'm using a 40 frame. I've been told the frames are the same so you really shouldn't be having any problems either.
36 1/2 ton pickup
on 38 car frame
with 1940 v8 24 stud
Scott H is offline   Reply With Quote
Old 06-04-2012, 01:50 PM   #3
JJOHN
On my 35, I spent the better part of the afternoon getting the drivers side on but they did finally fit.
JJOHN is offline   Reply With Quote
Old 06-04-2012, 09:28 PM   #4
felix37
felix37's Avatar
I have only heard positive things about the fit of Red's headers. I hope to put some on my 37' soon!
felix37 is offline   Reply With Quote
Old 06-04-2012, 09:48 PM   #5
G.M.
If you remove both front motor mount bolts you can raise the front of the engine at least 2 1/2"s. Nothing else but the oil fill cap needs to be removed. Don't dent the pan jacking it up. G.M.
www.fordcollector.com
Old 06-05-2012, 04:17 AM   #6
1936coupe
1936coupe's Avatar
ok thanks for replys, the headers i have are for a RHD car maybe they are slightly different?steering box/starter same side? will try and post pic, thanks GM will jack the engine.
Old 06-05-2012, 04:26 AM   #7
1936coupe
1936coupe's Avatar
Old 06-05-2012, 07:30 AM   #8
Scott H
Scott H's Avatar
Did you call Jim at Red's Headers and ask him or tell him you were having problems?
36 1/2 ton pickup
on 38 car frame
Old 06-05-2012, 07:35 AM   #9
1936coupe
1936coupe's Avatar
no good idea thanks,will call.
Old 06-05-2012, 07:35 AM   #10
fordcragar
fordcragar's Avatar
I'll second this suggestion. He seems like he is interested in any problems with his headers and might be able to help.
fordcragar is offline   Reply With Quote
Old 06-05-2012, 07:48 AM   #11
1936coupe
1936coupe's Avatar
sent email with pic,
