Old 12-31-2014, 01:07 PM   #21
Jerry in Shasta
Jerry in Shasta's Avatar
Default Re: Rough running cold.
Jack we all have to learn some new once-in-awhile. We don't know until some one tells us.
I've been around "A's" along time and never heard the phrase GAV until a couple of years ago.
Jerry in Shasta is online now   Reply With Quote
Old 12-31-2014, 01:21 PM   #22
Purdy Swoft
Purdy Swoft's Avatar
The main reason that so many have problems with timing is because they are trying to set the timing with the points and completely disregard direction of backlash while they screw up where the rotor tip points after the cam screw is tightened .
Old 12-31-2014, 01:28 PM   #23
Purdy Swoft
When I was a kid, I never messed with the GAV that much. I've learned a lot about fine tuning over the years. Back when I used Marvel carburetors they mostly ran good and I must have had the GAV in a good place because I never changed it at all.
Old 12-31-2014, 03:31 PM   #24
Loyd Nix
I replaced the manifold gaskets today but she still is acting up. While she sat for two months due to a starter/flywheel problem I never fiddled with the distributor or carbuerator so I am still in the dark. I know what the GAV is and use it as necessary.
I will press on. Happy New Year.
Loyd Nix is offline   Reply With Quote
Old 12-31-2014, 06:23 PM   #25
edmondclinton
Rarely do I ever see a GAV (not a Ford term) that works exactly like Ford's instructions on how to use it. Those Gav's have usually been screwed in too hard over the years, umpteen times, and also screwed out too hard thus booggering things up some.
Not too worry, usually. Just adjust wherever the engine runs the best while you're warming up or while you're going down the road.
edmondclinton is offline   Reply With Quote
Old 12-31-2014, 06:29 PM   #26
jwaldrich
jwaldrich's Avatar
I always referred to it as a fuel air/mixture. I'm originally a T guy and that is how I was trained. I am familiar with it.
John from Kapowsin
T&A Guy
jwaldrich is offline   Reply With Quote
Old 12-31-2014, 08:16 PM   #27
Fred K-OR
Fred K-OR's Avatar
John the GAV is just like the valve on top of the T carb (at least that was the way my old T had it). Ask away on questions you don't have answers for. That way I won't feel so bad when I ask all the questions I do.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 01-02-2015, 09:31 AM   #28
Loyd Nix
I cleaned and gapped points and plugs. Am using fresh gas with MMO. Tried different settings on GAV (the knob turns the rod). Replaced Bakalite distributor body. New manifold gaskets. Compensated for backlash when I retimed it (it does not over heat).
Runs fine down the road once warmed up.
Could it be a stuck valve until she warms up?
