Old 03-13-2017, 02:42 PM   #1
pgerhardt
pgerhardt's Avatar
Default Not model A but . . .
If you are into model A's then you must also be into things mechanical. I found this video of a steam powered saw mill cutting up a VERY big log fascinating. Maybe you will enjoy it as well.
https://www.youtube.com/watch?v=M57eCpaJuX4"
BTW every time I use the "Insert Link" button I have to edit out extra stuff that is inserted to make it work. Is it a bug, or I am doing something wrong?
pgerhardt is offline   Reply With Quote
Old 03-13-2017, 03:00 PM   #2
JDupuis
JDupuis's Avatar
Default Re: Not model A but . . .
When it starts to build up steam, it is a musical composition. Thanks Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 03-13-2017, 03:22 PM   #3
Rex_A_Lott
And you thought a Model A had a big flywheel.
Rex_A_Lott is offline   Reply With Quote
Old 03-13-2017, 03:31 PM   #4
Special Coupe Frank
Special Coupe Frank's Avatar
Good companion video, same family, I believe.
https://www.youtube.com/watch?v=_mKSKZau9qs
Special Coupe Frank is offline   Reply With Quote
Old 03-13-2017, 04:26 PM   #5
Jwilli
Jwilli's Avatar
Magnificent, thanks for posting.
Jwilli is offline   Reply With Quote
Old 03-13-2017, 06:08 PM   #6
dPokie
dPokie's Avatar
Send a message via AIM to dPokie Send a message via MSN to dPokie
Those large slabs were beautiful.
Thanks for posting.
dPokie is offline   Reply With Quote
Old 03-13-2017, 06:13 PM   #7
Ted Duke
I worked all day today, and I am 80, but, can you imagine doing that all day everyday.
Ted Duke is offline   Reply With Quote
Old 03-14-2017, 01:01 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I'm surprised that the box factory didn't use the steam from the engine to heat the inside of the building. They could have piped it through several cast iron heaters.
Old 03-14-2017, 04:29 AM   #9
RUNNERBUN
RUNNERBUN's Avatar
No shortage of off-cut timber to burn and power the steam engine.
Thanks for posting.
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 03-14-2017, 10:35 AM   #10
Rex_A_Lott
Thanks for posting.
It looked like they were working hard enough to stay warm. That's part of the beauty of wood heat, it warms you twice...Once when you cut it and once when you burn it.
Old 03-14-2017, 11:17 AM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
TOTALLY FASCINATING! I put off P**ING, 'til it was over. Once a tree is felled, the REAL work begins. A lot of the machinery is supported by WOOD structures, even.
Can you even imagine sawing the HUGE Redwood logs harvested in the West?
DON'T complain about the cost, when you floor your new FINE HOUSE.
I remember when the "throw away" slabs were used to cover out buildings, etc.
Sorry to cut this short, gotta' go "P"----
Bill Pain
"THE ASSISTANT GURU OF STUFF"
Old 03-14-2017, 06:31 PM   #12
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Wonderful video Paul, thanks for posting, I could watch that sawmill in operation all day. 100 years old and still going, that's what you call teamwork !
Barry B./ Ma. is offline   Reply With Quote
